Hi everyone, my wonderful singer accidentally knocked my Vintage V100 of it's stand at a gig. There appears to be no damage (thankfully) however after retuning the guitar it appears the intonation has gone off a bit.
Wht do i need to check and do in order to bring it back to full fettle?
I'm also really hoping there's no hidden damage as this guitar holds much more sentimental value than any of my others
Why?
I cannot see how an impact would create a need to adjust the truss rod - unless the rod was VERY tight fitting and the nut was already loosened.
If relief is too great, it will affect the intonation and it will need a tweak - but this and the knock are likely to be completely unconnected.
I had exactly this scenario happen with a friend's Gibson Melody Maker (one of the newer versions).
Unless the rod is already loose - but binding in its channel, a sudden impact should make no difference.
Has there been a noticeable change in action?
If not, my guess is that ICBM is right - the bridge has taken a knock and the posts have bent.
All seems ok except for a damaged volume knob
It landed face down - wasn't impressed.
X_X
Fortunately it glued up ok and as far as I'm aware he's still gigging it
The impact will not alter the setting of the rod - unless it is binding in the channel it sits in and the nut is already loosened - in other words, the only thing holding the rod under tension is friction.
The only time a truss rod needs tightening, is if there is too much relief. So the correct way to diagnose whether it's needed is to check the relief.
I'm not really sure in what way this is unhelpful.... In the absense of Facepalms, I have awarded you a 'Wow'.
All you have to do is be a little more pleasant in your posts, their have been numerous times you have come across as "I know better" and it wears a little thin.
Thank you guys not only for the advice but also sharing my pain
