Into a valve amp, a Digitech Bad monkey, gain set fairly low, bass and treble tweaked for a nicer boosted sound.
Currently either a Boss SD-1 or SD-2 into a solid state amp.
it really depends on what you mean by "best", though- more features? getting rid of the things some people don't like about a ts? getting rid of them while also being able to sound like a ts as well? cheap but still really good? sounding slightly different (in a useful way) while still being in the same ballpark? etc. etc.
I should finally get my Bad Monkey back tonight too. I'm looking forward to seeing how it works with my Roadster.
I'll see your sd1 and raise you my cheapo daphon sd1 clone which i got for (IIRC) £13 from marcmart and which (if mine's anything to go by) doesn't have the boss's bleedthrough problem in bypass. Not bad for a third of the price of the "real thing". Admittedly the boss version does look a lot cooler. And I'm guessing it's built better too, to be fair.
also the Bad Monkey is cheaper than an SD1 (it is from thomann, anyway).
But I agree, the sd1 is an excellent circuit- similar enough to the tubescreamer that you can use it in the same way and for the same thing, but different enough that it doesn't just feel like you're buying another ts-clone, either. For some things I prefer a ts-type pedal, for others the sd1.
Now please to buy it
