soundcloud.com/thecolourbox-1
its ok I've dismantled it all now, will see if i can get a different one that it'll fit in, been trying to shift my old Variax for months now so time for part ex me thinks
Remove it all and do a proper soldered wiring harness with the minimum of cable and it should fit.
If you've already done that, you may just have to deepen the cavity slightly. Quite a lot have a sort of 'block' in the middle which gets in the way. You can remove this without risking going through the back.
