Guys, quotes!
holnrewholnrew Frets: 8207
I've noticed a fair few people are writing their comments in the quotebox thingy of the person they're quoting, which is confusing.
If you can, please try to type below it. :)
My V key is broken
  • bertiebertie Frets: 13568
    edited August 2013
    sometimes it simply doesnt let you..............another bugette methinks.
    Ive found the only way to get around it is to post a smileee first,  then comment, remove smileeeeee
  • monquixotemonquixote Frets: 17603
    Yes tis a bug.
    You can also get around it by switching to HTML and typing at the bottom then switching back.
  • ddloopingddlooping Frets: 325
    It does sometimes work by clicking as close as possible to the left edge of the text area, under the quotebox thingy. :)
    it happens if you edit the quote,  ie to remove unwanted text
  • thumpingrugthumpingrug Frets: 2890
    Ive not had a problem.  Could it be a browser issue?  Im using safari
  • You can also use the "un-indent" button to get out of the quote region.
