Anyway, my point is definitely buy a 240v version in the UK and don't be tempted to save a few pounds from importing, but if you do use Thomann who have said they will honor the 3 year warranty no matter what!
Although it is an amp that is supposed to be great for all situations I have found it to be pretty fizzy at low volumes which you can tame with an EQ in the loop. The amps EQ is pretty strange, each knob is very interactive with the others and requires you to sometimes dial in the knobs to be in positions that you would normally find awful - so EQ with your ears not your eyes! Back on MR I had a few chats with kebabkid who also has a 36 about this. The clean channel is very hifi, but is excellent and cuts through well. Lots of head room at 36w, has a nice character. Cranked up the crunch channel is really good, I love it and use it way more that expected with my band on original stuff. It sits really well in the mix and has a nice amount of character to it, with a overdrive in front it can get there at lower volumes too, 5w it's awesome. The lead channel is great when cranked, I reckon you have to go just under half way on the volume on whatever wattage you are at to really get it to sound good though, which is way too loud for normal bedroom playing even at 1w unless you have tolerant neighbors. The MIDI is really well done, and adds a lot of options to the amp, and is something I would miss if I went back.
If the 36 remains reliable - gigged it and rehersed it for the last 5 months without problem - then it is a winner. However I have heard of lots of problems with the reverb unit becoming hissy (it is actually the weakest part of the amp in my opinion, too much high end to it) but this does appear to be on the earlier units, mine has been fine. It is certainly worth a try, great amp, just try to get a trial in where you can turn up to rehearsal levels. For bedroom use only I would recommend something else, maybe a single channel amp that takes pedals well, but for gigging jamming etc it is awesome.
Thanks for your opinions and account of your experiences with it. Now that you remind me I recall reading your early thoughts about it on MR. The voltage thing is odd but some of the UK dealers claiming to have stock are currently cheaper than Thomann so that should not be an issue although I do like the Thomann 3 year warranty and have had excellent service from them in the past. If I get one it will be for use with the band so I'll take your advice and try and crank it a bit if I can when I go and have a look at one. From what I've read and heard it will suit me very well. My only nagging doubt is the question mark about reliability.
@thomasw88
Interesting. I'll check the statesman out too. Thanks
It certainly has the features to make it practical amp if it has enough headroom in a loud band.
Reliability-wise, I had a noisy reverb early on but that was a valve and the shop replaced the head and no issues since (approx.a year old) and it's gigged.
The EQ, particularly on the OD channels, is weird and I don't think you get great results if you set everything to noon or on generic settings that might work well on other amps. Thomas Blug, H&K demonstrater, recommends bass and middle almost full up and treble at 10-11 o'clock- weird but it seems to work with a Strat!
At the mo, I prefer using my pedalboard into the very good clean channel as I like my various and different overdrive pedals, but I do occasionally put my delay and mods in the loop and the rest through the front, making use of all the amp channels. Either way, it works well. It takes pedals well but I think Ragingben will agree that it prefers lower gain ODs as opposed to anything too gainy.
Recommended!
Thanks for the info. I think I'll be mainly using the clean channel and I do have a board full of pedals so should be able to run things in the way you describe.
My one is the 240V model and I spoke to H&K prior to buying and they thought the separate head (weighs just 17lbs) and cab sounded better to their ears than the combo. Can't say on that one as I've not compared them, but IMHO the H&K 1x12 Celestion-loaded bass reflex cab sounds better and fuller than any other 1x12 cab I've had (Boogie, EV, Marshall) but some folks think it's pricey for what it is.
Unfortunately GuitarGuitar are no longer going to carry the range according to the guy I spoke to at Epsom. He said the reason was "problems with availability and pricing". So I'm probably looking at a trip down to GAK when I can find the time.
I was looking at the head and cab rather than the combo so thanks for the info about that.
