I've sort of become the bands unofficial sound man, although I know very little about it other than what I've read on websites and youtube videos I've watched.
I think I'm getting there, but we still struggle with monitor feedback. I've just picked up a 31-band EQ with the hope of using it in the monitor signal to help with that.
So I guess I need to learn how to ring out a room. I've bean reading about it and I just had 1 query.. when doing it, is it best to just use the mic in the main singers position on stage? and just set up as he would use it? I've read contradicting websites with some saying it should be on the floor, some on the stand, etc..
Just to check I've got the procedure correct:
- set monitor volume to unity
- set monitor send of channels to full
- set mic gain to 0
- slowly raise mic gain until feedback occurs
- use 31-band EQ to reduce offending frequency
- repeat until no more feedback
Assuming that's correct how high do I go with the mic gain before it's done?
That would work - just a slight tweak I use - set the channel gain for the mic to a reasonable level for your singer, to optimise the gain structure in the desk, then bring up the output level til you hear it edging into feedback and drop the offending frequency - keep the adjustments as small as you can.
Having plenty of headroom, careful positioning of the speakers and mics (check you know the pattern for that mic) should minimise the amount of adjustment needed.
Turn the pink noise on through the monitors, set one band to a high Q and a boost and sweep that frequency. At the room's "live" frequencies it'll resonate and you can then knock that frequency down - I normally start at -3dB, usually it needs a bit more cut than that. Rinse and repeat...
Most people who advised you meant the Behringer DSP110 - really clunky
Use the FB destroyer to find the most likely culprits, then remove it.
Leaving it inline will eventually kill all the freq bands in turn
Feedback
It was the DSP1124P i was looking at.
