... Right now the only place I can keep my guitars is at one side of the bedroom close to the window. Naturally being a Scottish winter it gets pretty cold close to those windows. Should I be worried about keeping my acoustic & (expensive!) electrics close to a cold window, even if they're in hard cases? When I pull one out the neck feels cold and eventually feels better/warmer given a little play. I'd be GUTTED if I found out a neck warped or something similar happened because of this.
I literally have nowhere else to put them and it's not like we can control the temperature in one room (just now, anyway).
One rule I always have, though - always keep them in their cases!
Where do you keep yours and do you worry about them?
EDIT - I'm sure a cold room is ok, as long as there are no major temperature changes, but it'd be good to get your input!
I found I can control the temperature in one room really well.
I turned the radiator off in the room and use a dyson heater/cooler to keep the temperature the same all the year round, thankfully the English weather doesn't vary that much normally so taking them out of the room is never an extreme shock
My YouTube Channel
We have a conservatory and in the winter even with the underfloor heating on it's too cold. In the summer it obviously gets very warm.
I was thinking the Dyson might be an ideal tool for trying to regulate the temperatures (or at least improve them) all year round.
When I had electrics they were in their cases too, under the bed, but actually closer to the radiator. I never found a problem. Even after leaving them for a few days they were always still in tune etc when they came out the cases.
If you can't control the environment in the room very well it's definitely a better idea to keep them in their cases away from the radiator.
Yes, they are excellent,
no it doesn't run up my bills as they are not on 24x7, they are only on when the temperature changes exteme.
if you put a device that displays the temperature clearly in a room, you'll find it doesn't change very much on a day to day basis, I bought one for something like £15 that has an alarm on it that triggers an alarm when it goes bellow a certain temperature or above a different one, in which case at that point I use the dyson to level the room out to it's ball park normal temperature, I really don't need to use the dyson very often, had to use it for a few days in the summer and thats about it so far.
as I understand it (the educated can correct me) it's not just temperature change, it's the variation of temperature that's the problem.
I find a little temperature drift in a room isn't a problem, which is why I don't use the dyson very often in that room, it's when the temperature changes to an extreme, and then changes back to the norm/opposite extreme, which is why I set the alarm to alert me well before so that I can keep the temperature constant.
If this was one/two guitars I'd not bother but as there are a fair few it makes sense to look after the room they are in.
