Would much appreciate some help with this please.
I've been delving into more theory this week and I've reached saturation point (not Joe Saturation, I might add).
I was looking for a scale that matched a Half Dim Chord (m7 b5) and found that Lydian Dominant contains those intervals. Don't ask why I do this to myself, I just like theory knowledge for knowledge sake, it interests me and it's probably for further down the road but I can't help myself.
I then looked at the other Dim Chords
Dim 1 - b3 - b5
Dim 7 1 - b3 - b5 - bb7
I came completely undone in trying to understand the Diminished Scale and whether both the Dim and Dim 7 fitted the scale. It was like the guitar equivalent of Snow Blindness.
I know I seem to have an obsession with scale patterns and half the time a couple of notes will suffice over a chord if it's going to change soon, but it seems to create "maps" for me.
As for Augmented Chords, I think I surmised that the Natural Minor scale contains those intervals. 1 - 3 - #5 (6)?
I've no probs playing the chords I can find those easy enough, it's just finding little patterns to play over them.
I'm OK with having something to use over the types of 7, 9, 11 and 13 chords, just puzzled a bit with the others.
If your head is now hurting, I'm not surprised.
Thanks for any help.
The 7th mode of the Harmonic minor scale matches the diminished 7th chord.
I don't think the Natural minor (R 2 b3 4 5 b6 b7) matches the Augmented chord because although you can rewrite a #5 as a b6, the scale contains a minor 3rd and the chord contains a major 3rd. You probably get the Augmented chord from another mode of the harmonic minor scale but ATM I can't remember which one it is. Taking the HM modes and working it out is left as an exercise to the reader
Feedback
Thanks , that is a glaring error by me. I should have spotted that re the Minor and Aug M3 and m3rd's issue and the Lydian Dom.
Locrian makes sense now for m7b5 as it's the last chord in the diatonic sequence before the octave. I'll have to stop thinking of the Parent Maj Scale and start remembering to think of the mode as the new root.
Do you think there it's daft to want to try and expand theory knowledge to stuff I might not use a lot?
@Jalapeno
Thanks, I understand that concept with the Dim7 Chords all being potential roots. I just couldn't find a definitive scale diagram, I may not have looked far as my head had almost gone at the time.
In this way you learn music and to improvise. Frequently revisit it as your tastes will change.
Here is the Pat Martino approach - learn the diminished chords and scales all over the neck - they're symetrical so more reuseable - learn each voicings implementations (repeated every over tone) and learn to sharpen and flatten stuff to make all the other chords.
Here is the Joe Pass approach - it's a minor chord with a major 6th - play as if you were playing over a II chord (so dorian mode) but avoid the 5th until it resolves..
Here's the Jimmy Bruno approach - shut the f*** up and figure out the notes that sound good - call it a scale and I'll come over there and mess you up - I ain't f***ing around - they're note choices and don't ever let me hear you callin' it a scale.
The Emily Remler approach is either use it with the melodic minor a fifth above the chord root or a semitone below the chord root, depending on whether it's followed by a major chord or not.
My take on it is this... Miles says "play what noone else is playing" so in the case of a disonnant chord - there's a need for playing consonant sounds, so the Joe Pass approach is a goodun.
That one deserves a Lol and a Wiz but it would only let me choose one.
Good advice.
Ta!
Thanks @octatonic, now realising what your username means ;-)
Cheers @Megii
Feedback
I think I just went blind
G7 -> A7 => G B D F -> A C# E G all told ( G A B C# D E F ) - I knew 2 dominants a tone apart = melodic minor mode but rather than think of that utterly redundant name (why learn hundreds?) - I think of the contents .. just playing the notes of the second dominant chord over the first gives a nice sound .. that'll become more familiar over the second chord -- repetition, resolution -- woo scary it'd sound.. planned, anticipated.
I think there is far more worth to be found in small tactics than there is boiling the ocean to find strategies - you'll find billions of strategies and names for them and by the time you've finished filing them you'll have arthritis and be deaf
There are only ever 12 notes, there are only really 3 types of chord: major minor and dominant - it's far far easier to learn the sounds of those 12 notes over those 3 types of chord - 36 combinations - than it is to learn exactly the same thing in bunches of eight (7,6 or 5) notes remembering it's thing (mode) of another thing (scale).
When you're playing over an unfamiliar piece of music sounds are your friends - not names. With a name you pick it... then scratch around trying to locate the root note then you can start playing the patter for that name... in jazz that's too late the music has moved so the tactics for finding a note have to be more immediate. I feel they're more honset and the results are more musical.
