I'm having serious problems with string breakage on an old MIK Avalon dread. Always the G and D strings, always at the bridge, and always within a few weeks of fitting (only a few playing hours). The guitar is only played once or twice a week or less and stored in a Hiscox hard case the rest of the time.
The obvious culprit would be the bridge (stock plastic compensated saddle), but I can't feel any rough spots- should I be able to?
Other than that, what else could be causing it? I use a very heavy pick (V-Picks 2.75mm) and a fairly heavy right hand, but I've been playing like that for years with no problems except when strings were visibly worn out already. I've been using Fender Dura-Tone strings, but I think I switched to those before I started having problems.
Do I just start a process of elimination until I find something that makes a difference, or is there a better way to get to the root of the problem?
How easy is it for a layman with no specialist luthierin' tools to fit a new bridge saddle on an acoustic and come out with a playable instrument?
As ICBM says, it's probably just a rough edge and once that's gone you should be good for a while.
contactemea@fender.com
OK. Replaced the most recent breakage (G) during the week (left the rest as only just re-strung the thing a week or two ago and barely put any wear on the strings yet), sanded down the bridge saddle with 600 grit paper until I couldn't even feel the tiny dents I was sure were too small to do any damage to anything.
Guitar survived its outing on Sunday morning without incident. We continue...
