contactemea@fender.com
Really? Doesn't look like much wood (and hence weight) was removed.
yeah, having done weight relief holes they would need to be a lot more of them drilled deeper to make much difference. then maybe you can reduce the overall weight by 20 - 30% tops. to go beyound that you need to start with proper chambering
these 3 holes will be an ounce or two at most
Instagram
I thought you might be joking - but you neverknow what somecompanies will claim is a feature! best bet is a smiley face on the end of a joke
Instagram
