So this evening I decided to do some "clever" power scaling mods to my tweed deluxe build. I bought a new power transformer with a 190v and 275v taps on the secondary, so theoretically you can run it at half power using the 190v. It's been working perfectly up until now. Anyway, seems like I messed up the wiring on the selector switch and ended up connecting ov directly to 275v on the secondary ... Doh. The transformer duly released a little puff of magic smoke and smelled pretty foul.
I was convinced that it would be blown, but unconnected to the amp it measures 288v across the secondary, just as it should. So cautiously I hooked it back up to the amp, with the power tubes pulled - voltage at the first filter cap was a nice healthy 400v (solid state rectified), so it's exactly where it should be. However when I put the power tubes back in, strange popping and crackling noises from the speaker, and the voltage at the first filter cap fluctuates rapidly between 120 and 160v.
I guess I already know that I need a new power transformer, I'm just curious if anyone has experienced this before - I thought if a pt was damaged the windings just wouldn't work, or put out a much reduced voltage? Having thought about it a little, I guess the transformer could still give a decent voltage, but fail when a certain amount of current is drawn through the circuit? I just find it interesting, and wonder if any of you techies have a theory?
Anyway, there are my ramblings, maybe this is one for
@ICBM and his vast technical skills ... Cheers!
