(formerly miserneil)
Follow all the advice above for technique, but I would use a slow epoxy for the glue as it will stand a better chance than wood glue if there is still contamination in the wood.
I generally go with titebond for fresh breaks and epoxy for anything with potential contamination
Instagram
Instagram
i like z-poxy 30 min epoxy - but you won;t normally find that at screwfix or wickes
araldite is the brand you see everywhere. Its harder to work and really stinks. its also harder to clean up
from those shops I would try this one
http://www.wickes.co.uk/Gorilla-Epoxy-25ml/p/121097
its quite a fast setting epoxy so your eally do need to practice your clamping method first. don't mix any epoxy untill you are happy you can get it positioned and in clamps nice and quick. also warm the epoxy first as it will flow a lot better. Either stand it on a radiator or put the unopened tube in some hot water for a few minutes
It does say it only needs 30 mins to set, but still give it 24 hours in clamps before stringing
Instagram
Yes, it was a task and I must admit I thought I had bitten off more than I could chew at points but with a bit of patience (and inadvertently discovering a few tricks of the noted relic/aged refinishers) it is undistinguishable on the face.
