I've made the mistake of saying I know a little bit about PA systems, so our band has decided that I should take charge of choosing one and being the 'sound man.' GULP! I have been looking online and the QSC range has rave reviews and I've just seen a pair of their K12 1000 watt powered speakers go for just over a grand on eBay. We're a 5 piece punk band and will be playing small to medium venues with bass/snare drums mic'd and an overhead mic for the drums and probably bass and guitars occasionally mic'd too. I understand getting more way wattage than you need, but can anyone recommend a system that they use for the same set up? Mackie, of course is another option, maybe Peavey, but I just wondered what your thoughts are?
Thanks
Never ever bloody anything, ever!
If you are in a punk band and drums and bass are going through the PA, you will need at least one sub, preferably two. 12" tops will not handle low end for any length of time at volume without blowing speakers. You don't have to spend a fortune but don't buy cheap either. Ignore wattage to an extent and look at SPL ratings. Thats a more tru indication of volume. You may find a speaker that is 1000w only has a 97db SPL whereas a 600w speaker has 102db.
If you can pick up an old Peavey HiSys rig then you're golden. Bitch to lug around but you will be heard. It will out live most things that have ever been made. I'm currently trialling the new powered version and so far so good but it will be an investment financially! Powered vs passive is up to you. Depends on money, convenience and knowledge. PA is a nightmare but very interesting when you get into it and you can take it as far as you need to.
