Nomad
It was a particularly nice guitar (I just remember it having 'something' special about it) with some nice Amalfitano pickups, so it was noticeable that the tone had changed slightly when (some months later) I re-fitted the pickups in the copper scratchplate (which was made by another friend). In fact, I thought it might have lost just a little about whatever was special about it in the first place - I think I preferred it before. It seemed to be slightly more rounded, slightly fuller but, at the same time, slightly less 'lively'. A little more 'reserved', maybe?
I've often wondered quite what was responsible for the change (which, I stress, was slight but seemed real). The guitar was definitely 'quieter' (in terms of buzz and interference) but was the extra screening dulling the highs a little? The new copper 'plate meant the guitar was also a bit heavier - could the extra mass be the cause? Another thought I had was that the copper 'plate was more rigid than the plastic one - was the suspension of the pickups from this (a 'stiffer', less microphonic mounting) a factor? Or a combination of causes?
Whatever the causes, the guitar sounded different with the copper scratchplate.
Thanks folks. Most interesting.
Minging though it may be, I was thinking of some brass sheet (allowed to naturally tarnish, I should point out). This would be for a lap steel, incidentally.
Nomad
Don't think I'll be going that far.
The plan is a meranti body (got the wood in yesterday) and I'm thinking a dull matt brass plate. When I get a chance, I'll mess around with oiling an offcut of the wood and see how it looks with the brass (of which I have plenty of bits and bobs). The other option is some tort plastic, which I have a sheet of.
Nomad
https://www.youtube.com/watch?v=LvQuJ1xnjhc
Presumably because he's our overly-cheery shipboard computer.
The tort scratchplate doesn't really go with the wood with just a lick of oil on it, but the brass does. I might try a bit of stain and see how that goes, but leaning towards the brass so far.
Nomad
Nomad
Edit, wink was at steamabacus for getting the HG2tG ref, though I suppose nomad should get one too. Oddly ended up accidentally winking at people twice yesterday. Explaining it probably makes it worse...
