i have wanted to get a bass for a while now (but not really having a clue as to what bass).
i recently came across the aforementioned bass as i was looking at basses
now i have never played any fretless guitar before,but i really am drawn to it for some reason (also have been watching a lot of michael manring on youtube too).
i will only be playing for my own enjoyment,and like the idea of sliding on the strings,and trying to get weird noises from it e.t.c too.
am i mad to consider a fretless bass as my first bass.
i would like to learn classic bass tunes also i'd like to add.
what do you think?
If fretless bass appeals to you, the only way you'll really know if getting one is the right thing to do is to get one. They're great fun for solo noodling at home.
As mentioned, flat-wounds are kinder to the board. My 5-string Yamaha has some light wear from rounds used by whoever had it previously, and the balance across the strings was a bit crap (in particular, the B string was too ringy). Putting Picato flats on it made it much smoother to play and the string balance was transformed. That has active electronics, and can still get a pretty bright tone if desired. With a little roll of felt under the strings near the bridge, it's quite thumpy and more like a double bass.
The intonation thing just kind of happens. If you include a few open strings as pitch references, you can develop an ear for when fingered notes are out (as will playing along with recorded music). They have loads of sustain, so you can play an open string and add notes on top on the other strings.
If you haven't already, you might want to consider a 5-string instead, not so much for the extra 5 semitones (although some say that "Bass" begins with "B", and I wouldn't argue), but for the ease of getting a bunch of lower notes across the finger board. Strangely, for a first bass, I found that getting the notes I wanted was no problem (I'm not a real bassist by any stretch). If I were to consider getting a second bass, it would be a 5-string fretted one without a doubt.
Nomad
