Even with the amp and the cab correctly matched, running at 16 ohms will sound different from running at 4 ohms - it's more due to the difference in damping and inductance than whether you're using "the whole winding". (Which is only half for a 4-ohm tap on a 16-ohm winding anyway, not a quarter - since the impedance ratio is the *square* of the turns ratio.)
The Fender Tonemaster was designed unusually: you can use the impedance to vary the sound/feel:
D. IMPEDANCE SWITCH - This is labeled LO, MED and HI. This switch serves two functions.
One, to set the output impedance of the amplifier to best match the speaker impedance for maximum power. Second, to enable the amplifier to better achieve the cranked-up sound at a lower volume. On the B CHANNEL, with a single Tone-Master enclosure, this switch should be set according to the setting of the B CHANNEL volume knob: For volume settings of 3.5 and lower, LO would be the appropriate setting. For settings of 3.5 to 7, MED is best. For settings above 7,
HI will produce full power and tone. This switch will not damage tubes or reduce tube life at these settings. What it does do is increase the gain in the LO and MED settings and thereby better
approximate the Full volume sound at a lower level than by adjusting the VOLUME alone. With a single 16½ enclosure, LO will produce 30 watts, MED will Produce 60 watts, and HI will
produce a full 100 watts. With two 16½ enclosures, (an 8½ load), LO will produce 60 watts, and MED will Produce 100 watts. In the A CHANNEL, the switch has the same function, although
blues players may like running the switch on LO all the time to get that great crying tone.
Conversely, a player looking for a New Wave Strat® tone might like the sound of the A CHANNEL on HI.
But the idea of running the amp at 4 ohms into a 16-ohm cab to get "a better tone" (ie more distortion) at lower volume was an occasionally recommended 'trick' with old Marshalls when I stated repairing amps, and that isn't a good idea... either old Marshall transformers are inherently weaker or there's some other factor, because it quite often led to a blown OT.
Running a vintage Fender head (4 ohm output) into a standard vintage 16-ohm Marshall cab is a bad idea too.
I also tried once different impedances with the same cab into the same amp (it's a cab with series/parallel wiring for 4 or 16 ohms and the amp had multiple impedance taps), and while I thought there was a very subtle difference, it was within "is it just the placebo effect?" range and I figured it wasn't worth worrying about. Obviously that's not a scientific test, maybe it makes more difference with other amps and speakers (not to mention, going from series to parallel wiring for the speakers could also affect the tone), but I figured it was subtle at best.
I knew it needed a more expensive transformer - I wasn't recommending it, I just thought it was interestingly unusual
