Livening up Drop tunings
Drew_TNBDDrew_TNBD Frets: 22445
I feel it's more common to fall into the same old patterns when you're in a drop tuning than when you're in a standard tuning. Maybe I'm wrong, but the whole 'power chords with one finger' thing can become a bit of a prison. Post tips here on how to liven up drop-tunings.
Here are mine, which admittedly are probably really commonly know. But maybe someone will get something from them:
- Add minor notes to your power chords with a simple additional fingering on the 4th string, two frets up from the main fret. So something like:
D -10--
A -7---
D -7---
- You can even take this a step further and create melodies within the chord. For example, one of my bands songs called Fractal World does this:
C --8-----8--8--8--8--7-----7--7--7--7----|
G --5-----5--5--5--5--5-----5--5--5--5----|
C --5-----5--5--5--5--5-----5--5--5--5----|
C --------------------5-----5--5--5--5----|
G --8-----8--8--8--8--5-----5--5--5--5----|
C --10----10-10-10-10-8-----8--8--8--8----|
G --8-----8--8--8--8--8-----8--8--8--8----|
C --8-----8--8--8--8--8-----8--8--8--8----|
C --13----13-13-13-13-12----12-12-12-12---|
G --10----10-10-10-10-10----10-10-10-10---|
C --10----10-10-10-10-10----10-10-10-10---|
So you can see that with my pinkie finger, I'm creating this additional melody within the main chord progression. It's a neat trick and can liven up a drop tuning no end.
  • randomhandclapsrandomhandclaps Frets: 20521
    I have spent a lot of time thinking about this particular thing. A couple of years back I was in a band and started writing feverishly in drop D, or C#. I'm now revisiting that stuff to record final versions for a project and I realised how much more adventurous I was to start with when I was actually conscially thinking about note structure (like it was a slide tuning) rather than trudging out riffs like it was a gear demo.
    Another cool thing to do is drop into drop-d or drop-c or whatever.. but use fret 2 as you're pedal note. So you're essentially still in standard mode, but you can always pedal from an open d chord back to the 2nd fret. Good for making huge jumps across the neck.
  • DeijavooDeijavoo Frets: 3298
    The whole drop tuning trap is one I've argued with friends about for what feels like a lifetime The open chord ends up so obvious in so many songs but then again, doesn't standard E in standard tuning?
    Good thread idea and sharing dude.
  • PolarityManPolarityMan Frets: 7284
    I quite like playing whole tone intervals too, I think it sounds a bit like a seventh chord played at the same time and creates an ambigous root note that you can strengthen to hear either on the A string or the D string via the other guitar / bass. Like this moveable pattern from one of our tunes called Jedidiah:
    |--777-7p5-5-7-|
    |--333-3-3--3-3-|
    |--333-3-3--3-3-|
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
