FS, 5w valve amp. Kustom defender.
birdobirdo Frets: 24
Due to my current guitar room getting turned into a nursery I ve got to off load some of my gear. So up for grabs is kustom v5 "the defender" amp. Which I a little 5w tube amp. With a simple control panel, just volume and tone. On the back there's the option to disconnect the speaker and run out to. 4,8 or 16 ohm load. Ideal little home practice amp. As there's not separate gain control the only way to get any crunch is volume but I use a tech 21 Oxford pedal. Which gives a real nice overdrive. I could do a deal for the pair. Both are in mint condition. Amp £100 posted. photo image_zpsbd74f3c4.jpg
