Major 7th chords
Cmaj7 or C <little triangle> 7 pleez.
"CM7" is bad enough in print (even though you're supposed to suss from the upper case that Cm7 is not meant) but in handwriting - if you perpetrate it you should be shot.
Anyone else hate the M7 notation?
  • Maj7 chords are for sissies anyway so who cares?
  • If liking them makes me a sissy, then I'm a sissy :)
    BTW I also like minor, dominant, half-diminished, and diminished 7ths. I don't think I'm discriminatory, except for the context in which I use them ;)
  • frankusfrankus Frets: 4719
    My philosophy is this: CΔ - chances are very very strong that I'm going to try it as CΔ7, CΔ9, CΔ11 and CΔ13 at least once anyway ;)
    Equally I don't bother embellishing Cm to Cm7 as I like Cm13 and Cm♭13 and seeing which does the trick.
    As for Δ7 being for wimps, try subbing a Diminished chords for a Δ7 a semitone below.
  • wotyer fink of the notation though @frankus? whenever I see 'm' (or even 'M') I read it as minor, and then have to perform some kind of mental correction because somebody has used upper case to mean major. and in handwriting, it's just effing ambiguous!
    I always use a delta, most of the fake books I've ever used, use a delta for major or Maj.
    Band in a Box uses " Maj" which is clearer than an upper case M.
    I don't like capitalisation in notation, although at one stage I used to write Nashville notation thusly: iii iv ii V I - I got told off by Dario Cortese :D
  • equalsqlequalsql Frets: 6104
    Are we talking maths here with all these triangles? ... C and the rate of change of 7, C and the rate of change of 9..  my head hurts.
    Cmaj7 chords are lovely happy spring bright things that should never be hurt and should have their own happy smiley thread...anyway!
  • GuyBodenGuyBoden Frets: 744
    Yes, the triangle sign (Δ) is popular, I think the triangle originally signified a triad.
  • mike_lmike_l Frets: 5700
    I was taught M7 can be read as minor7, so to be clear it's Maj7.
    I think I've played a Maj7 once in the last 5 years.
  • Just to be clear: Cmaj7 should be written that way or as CΔ7 ...
    ... but NEVER as "CM7"
    Agreed, CM7 is Dunmow ;)
  • @frankus well played sir!
    edited August 2015
    I think Dunmow is CM6, Braintree is CM7
    Braintree?
    frankus said:
    Braintree?
    Ah yes, CM7 is Braintree, Dunmow is CM6.
    ok
    Anyway, I've only ever played Maj7 chords when playing old Jazz standards. I never play the fifth with a Maj7, so adding more flexibility for the soloist. With a band, you really only need two notes the 3rd and 7th.
    bass players tend to get territorial over the root and fifth ;)
  • ArchtopDaveArchtopDave Frets: 1368
    Major 7th's can be Minor 9th's in disguise.
  • Major 7th's can be Minor 9th's in disguise.
    im intrigued. how so?
