I only play at home. I fancy a different amp, something not too mad and powerful, needs to be played quite most of the time. I have very limited knowledge of amps.
• I currently have an H&K switchblade amp, but I have never really bonded with it. I want to get something a bit less big and powerful.
• I like Satriani type tones, and SRV type blues tones, and sparkly clean Fendery tones.
• I'm OK with modelling amps, and I really like the idea of a head (if not too massive) and cab. The room I play in is small, so I usually sit on the amp, which makes it hard to alter. If I had a head I could park it on the table top.
• Ideally I like built in reverb and delay, they are the only effects I use and I can't be bothered with pedals.
Any suggestions gratefully received ....
