Hi all,
I've built my first couple of pedals and one works fine, but the other is intermittent.
I'm no electronics expert, but I'm keen to learn and I'm trying to learn-by-doing. However, if you follow the instructions and it all works fine, you don't really learn anything - which is what I found with my Ampmaker build a couple of years ago.
I've been looking at various things on youtube to try to help me with this intermittent pedal. I put together an audio probe and have traced the signal back to a particular place, but the component there seems to be working.
I have a DMM and so I've been checking continuity and voltage of various bits and bobs, but I don't really know what I'm doing or how to interpret my findings.
Do any builders have a specific method such:
Does pedal work Y or N: N
Does this bit do what it should Y or N:
Have we tested this Y or N:
Is the reading for X correct Y or N:
etc etc etc...
Or one of those cloud charty things - if you know what I mean?
Any help extremely gratefully received.
Ta
DannyP
Bandcamp
Spotify, Apple et al
Cheers for the replies chaps.
It's a Hotcake clone from the Poodle.
When I first builded it, it worked fine until I closed the enclosure, at which point it cut out - bypass was fine but it had become a killswitch.
I covered the interior of the enclosure base with insulation tape - still intermittent.
I experimented with pieces of foam above and below the pcb - still intermittent.
During this period of experimentation, the pedal would often come back to life when I brushed the underside of the board with my fingers by accident - usually around the bigger caps.?.?.?
I disconnected the 9v and Ground wires and flipped the board over (originally the components were facing down towards the base, now they face up towards the pots, which it should have been in the first place I guess - inexperience).
In doing this, I bolloxed up part of the copper track where the 9v connects to the boards, so I ended up wiring the 9v directly to the first resistor in circuit (plus I needed to take the resistor going to the LED off the board, no biggy).
I boxed it up again and it worked fine and sounded great for about 2 days.
Then it died again.
Then I noticed it was making some weird, clipped noises when I strummed really really hard, so I opened it up and it popped back into life. Then died again. Then I wiggled the board and brushed some of the connections under the board with my finger and it came back to life. Then I closed the enclosure and it died. Then after a bit it started working - you get the picture....
I would suggest the generic sequence runs something like:
0) Try a new battery
1) Check power & ground voltages are making it to the board and to the supply and ground (or -ve supply) pins of any chips (measure at the chip with both meter probes, or you won't find missing ground connections - how do I know...?);
2) Check any internal '0V' supplies (the junction of R3, R4 & C2 on your circuit) - should be somewhere close to 1/2 of the supply voltage;
3) Measure C, B & E voltages of any transistors (not relevant here) - B should be ~0.6V different to E
4) Measure the voltages of '-' and '+' inputs of any op-amps (pins 2 and 3 of your chip) which should be the same as each other and close to the voltage measured in (2)
5) Measure the voltage at the outputs of any op-amps (pin 6 of your chip). If the voltages in (4) are as expected, then the output should also be fairly close to the voltage measured in (2)
For most simple pedal circuits, that will establish that the electronics are basically functional - if anything is out of line, look for the cause of that problem.
If it checks out, it's likely that the signal isn't making it to the board, or isn't making it back again, or there is a wiring mistake / missing component / etc.
Unfortunately intermittent stuff like that is 99.9% of the time something 'mechanical' - a poor solder joint, cracked PCB track, whisker of wire touching, or something shorting out. As such, I think you're most likely to find it by mechanical means - check over all the solder joints with a magnifying glass, make sure that nothing is shorting out - especially whiskers of wire on the interconnecting wires. You may be able to localise the fault by tapping things - if you can make the fault come and go by tapping a certain area of the board, then you've narrowed the search down.
Stuff that's not so easy is bad contacts on jack socket switches or dead foot switches.
HTH
Thanks MisterG, have a wisdom.
You're quite right, it's a Chilly Biscuit.
I've done a few of those steps, but there's plenty of homework to be getting on with there, I'll see how I get on.....
Type "solder dry joint" into google images and look for something similar.
Having read all you put I would bet that the issue is a dodgy solder on one of the wires to the board or on the pots. When things are wriggled around it's incredibly easy to stress iffy joints.
Can you post any photos?
http://pedalparts.co.uk/wp-content/uploads/2013/08/ChillyBiscuit.pdf
(Or on the 'Chilly Biscuit' link here:
http://pedalparts.co.uk/category/diagrams/
if the link to the pdf doesn't work!)
Thanks for the comments, lads.
I'm just going to be looking after the kids for a few hours, but I'll be back on later with pics and details.
(also I don't seem to be able to click 'Wisdoms' at the mo, but I'll dole them out later if it starts working again!)
OK here's some pics.
I tried 'resoldering' anything that looked even slightly dull - resulting in the board looking a bit messier than before.
For a while, wiggling C3 seemed to bring it back to life, so I heated the legs and whacked a bit more solder on the joints - now it doesn't seem to work at all!
When it was working, it worked perfectly - great sound, pots did what they were supposed to - but when it cuts out, that's it.
Getting a bit sad about the whole enterprise now
http://i611.photobucket.com/albums/tt192/p1eces/chilly3.jpg
http://i611.photobucket.com/albums/tt192/p1eces/chilly1.jpg
