Try this: in C major, the pairs of notes that make 3rds are CE DF EG FA GB AC BD, similar applies to any scale, just pick a pair of notes two scale steps apart. First, play them up the same pair of strings, eg the 5th & 4th strings, so: frets 3&2, 5&3, 7&5 etc. Doing it up the same pair of strings will show you the distance relationships between the pairs of notes, as well as the distance relationship between the lower of "this" pair and the lower of the "next" pair. Next, find their equivalents going across the neck, using 2 strings. If you stick to any one "scale pattern" you might find that you pick two notes on the same string - which isn't wrong if you want a convenient arpeggio shape but it means you won't hear them played together.
