We think we know what an octave is. It's like going from the open string to 12 frets up that string, and you get the same note name, right? But the 12 frets and the 8 note names are only consequences of the way in which we divided up something else. The
something else is the physical phenomenon of our sensing the "same note" when we double or halve the frequency of a note. I looked up the word "diapason" in connection with something else that I was reading, and found that one of its meanings was that "same note" thing when we double or halve the frequency of a note (
http://en.wikipedia.org/wiki/Diapason_(interval)).
Its funny, but the concept is so fundamental ('scuse pun) yet we don't have a commonly used name for it. Even physicists, electronics engineers etc talk about slopes of "so many dB per octave" and they're not interested in 8 notes or 12 frets, only the way their function changes with frequency.
As the word diapason also has other uses maybe we shouldn't start using it in this context, but octave surely is irrelevant if your, er, "octave" is split into 5 notes, or you are playing a sitar with 24 frets between the nut and halfway along the speaking length of the string.
We need another word. Suggestions?
In physics they are harmonic partials and the octave is the 1st harmonic / 2nd overtone or 2nd harmonic.
As viz says the word octave arises from the arbitrary (but mathematically quite logical and useful) way we choose to subdivide the naturally occurring "whole".
I am sure there are other musical terms that are traditional rather than accurate but I think it would be a significant uphill battle to replace the word octave in common usage.
So in guitarspeak the open string is the first mode, the 12th fret harmonic creates the 2nd mode, the 7th fret harm gives the 3rd mode, and the 5th fret the fourth mode... All the even-numbered modes are heard by our ears as octaves above that original fundamental note.
The points on the string that correspond with those fret points are called nodes.
Physics has an answer for everything
