Practicing double stops from scale notes up the board, one string, two, three, four, five or six strings apart is a great and obvious, although often overlooked way to not only create ways of playing new chords and also make easy sense of the chords tonality from the basics up, as well as identify parts of barred whole C open style chords etc. With just two notes you can make them major or minor. As well as all that they de-mystify and develop your ear.
Starting out with two notes on two stings side by side, eg, the D and G strings, you can play a minor sequence or a major all the way up the board and kind of break out of your position playing and make complete fluid sense of four note chords so loved by Jimi and John Frusciante as well as creating new licks and stuff by learnings them relative on all the strings.
Also it's a great way to add thickness to an acoustic solo, or electric pop/rock style with muted strings between the notes, such as octave chords etc on the A and G strings for example, as well as subconsciously learning bass lines, finger picked chords and positions for your acoustic style, for example by playing a minor sequence of doublestops with the A and B strings only.
Warren Zevon 'Carmelita' solo, RHCP 'Snow' chorus, most of the Foo Fighters, Blink 182 and even Kelly Clarkson are just a few that come to mind.
EG Snow, RHCP is the best example, the B and E strings are Octaves and the A and D strings are a simple minor sequence, it's all there and sounds full whilst also being subtle and stripped down. It's so obvious when you think about it, but inaccessible when you don't know the tones, that is what makes it so catchy and Frusciante so good IMO and most of his RHCP playing is done in a similar vein. You'd play it by strumming it and muting the other strings (E,G.E) with your left hand (First finger G and E and thumb E) whilst playing the seventh fret note with your first finger, eighth fret A with your second and tenth fret B with your third or fourth. Jimi did get there first though.
E........................................................................................................8----7---12---10--------------------12
B-10----12-----13----------17----15................/.....................8---8---10---10-----17----15-----10
G........................................................................................................9---7---10---10--------------------10
D-7-------9-----10-----------14----12................/....................10--9---12---12-----14----12----12
A-8------10-----12-----------15----14.............................................................................15----14
E-
Foo Fighters Everlong bridge:
E----------------------------------------------5
B----------------------------------------------5
G--4-4-4-6-6-6-7---9-9-9-11-12-11---2
D----------------------------------------------2
A--2-2-2-4-4-4-5---7-7-7--9--10--9----0
E
F Major:.....................................F Minor:
G-2-4-5-7--9-10-12-14..............1-3-5-6--8--10-12
D-3-5-7-9-10-12-14-15..............3-5-6-8-10-11-13
A Major......................................A Minor..............................Octaves
E
B-2--3--5--7--9--10-12--14........1--3--5--6--8--10-12-13.......3-5-7-8
G
D
A-0--2--4--5--7---9--11--12........0--2--3--5--7--8--10--12.......5-7-9-10
E
It all helps.
