Right .... that gungy old Shergold pickup is now ready to be rewound and re assembled
Exhibit a.
a bobbin displaying all the signs of corrosion! Smells foul too!
measured the wire diameter by the tried and trusted method of taking ten turns around a screwdriver, then measuring the width of the 10 turns with a digital vernier ... and dividing by 10! This wire was so corroded and nasty that I ended up taking 20 turns around to get an accurate average!
with .056mm chosen, the old wire was stripped off to reveal a curious and very, very delicate 'cut and shut' bobbin.
Seems to have been made by sawing down a much taller bobbin and gluing it with something resembling model aircraft glue.
I had to reinforce it with fillets of superglue and make a cradle so that it wouldn't fall apart in the winding machine!
Mounted in 'Tweedle Dee' the winding machine
Continued shortly ....
Ash has done an incredible job on a practically irreplaceable pickup. It sounds exactly 'right' - just like a Shergold should - and its squeal free!!
I'm so grateful and impressed.
Thanks, Ash!!
Give over!
Your repair threads are always fascinating, but this one goes above and beyond. I can't imagine doing this kind of thing makes much financial sense, but it's great to see what can be saved.
