IIRC @ICBM used a regular spaced Duncan Custom Custom in his PRS
My YouTube Channel
My YouTube Channel
My YouTube Channel
Okay, at the risk of repeating myself for the umpteenth time ... DC resistance is no real measure of output power. it is number of turns of wire and it's magnet strength that dictate a pickup's output ... not it's resistance. a pickup wound with 10,000 turns (split between the two bobbins) of 42awg wire as used in a PAF for example, will measure about 8k. The same number of turns of thinner 43 gauge wire as used say on a Duncan JB will be about 10k ... but they will be EXACTLY the same output in volume and power. Unless you know the wire gauge used in a pickup DC resistance is a meaningless figure.
My YouTube Channel
In my personal experience however, with a Vintage Strat bridge 2-7/32" inch spacing, I found that the 1st and 6th strings sat outside the pole pieces of the bridge pickup - as you can see here.
[Imgur](https://i.imgur.com/IG6tKBr.jpg)
On the bridge pickup, when played clean - it didn't affect the volume of the low (6th) E or even the perceived volume of the high (1st) E string, which sounded fine.
However, with the amp set on the edge of overdrive, my 1st string was distinctly quieter on the bridge pickup (not in the other four positions of the selector switch). I got more 'saturation / sustain' on the other strings - and my 1st string remained 'clean' so to speak.
I must admit that in actual fact it didn't make tuppence difference to me since I don't use my Stratocaster for distorted sounds - but the obsessive-compulsive in me needed to solve the problem.
I changed the bridge to a 54mm spacing affair - and the problem went away.
Your low E was about to jump, lemming style, off the board anyway :-)
I kept it that way so as to allow my High E to come in a little bit (since I only ever bend the 6th string downwards anyway). It didn't help the 1st string either :-(
Is that because the nut is 41mm (1-5/8") rather than the 43mm (1-11/16") on mine?
On a 41mm nut, my fat sausage fingers wouldn't be able to play anything close to the nut (and I'm an eye surgeon )
To me, it looks like the modern saddles are slightly wider - they come closer to the edge of the bridgeplate, and the strings are slightly wider spaced than the pivot screws, which they aren't on the original.
All Fender Strat pickups neck, middle and bridge are 52mm spaced, so the passage over the poles is dead right only on one out of three pickups ... which should be the middle pickup, so that with the neck pickup the strings pass slightly inside the centre of the poles ... with the middle they are bang on, and at the bridge they are fractionally outside. To my mind it has to be the bridge.
Rules ... what rules?
