(16+16 wired in parallel = 8)
I''d probably just do a direct swap and keep the wiring but you could simplify the wiring and take out the option to have the cab in stereo by just having one socket and the speakers in parallel - I know icbm isn't a fan of the switching on cabs.
It'll be simpler to fit to just swap out the speakers - they probably have spade connectors so you once you open it up you just unplug them and fit the new ones - nice and easy.
Err, you might have a problem with a straight swop.
Celestions use a 5mm push on receptacle but many other makes use the more common 6mm and thus the existing terms' won't fit.
I note too that the Invaders are 2dB less sensitive than the V30s? Might seem a bit less punchy?
But we await ICBM to sort us out!
Dave.
Ive emailed WGS who have said their speakers are 5mm like celestions so I guess I'm good to go.
The sensitivity doesn't bother me, I'm not even using the vintage 30 cab as I dislike them so much. I'm currently playing through g12t-100s which are 97db and then being lower than the v30s hasn't bothered me.
Thanks for everyone's help, this forum is great
Chris
But yes, this forum is pretty good. try the gear page if you want to see what we strive not to be...
