If your trem arm rattles, they do one that doesn't too, which is good but £30 so it depends if it bugs you that much. I never have worried about it tbh.
Mastery bridges people rave about but look like they fell off a mountain bike, which is pretty grim. I'm sure they work perfectly but are crazy money.
I've not liked the Buzzstop as it loses something for me and if your strings are heavy enough you really don't need it anyway. In fact most 'problems' disappear with heavier strings or a shim in the neck pocket.
Good pots and switches are always worth it - I tend to get one of Mojo pickups wiring looms as they are perfect and so neat it is a joy to fit under the pickguard.
Which JM have you got? (Which probably should have been the first questions)
I saw an update on ebay that he had them in again (iirc) Here you go
Other than swapping the metal s/plate for a white/black/white one, I kept it pretty standard
I like Graphtech saddles rather than mustang bridges, but they do change the sound slightly (a bit more zing and a different sustain curve) which you'll either love or hate or not notice!
