This is not the same issue as Auldreekie's thread. I am getting different tones when engaging mine.
I had my Wolfgang Coil Tapped or Split back in 2000 when I bought it. It was done at the shop I bought it from and I've noticed since I got my VSOP guitar last year, just how noisy the Wolfgang can be.
At the time(2000) I knew less than zero about guitars and I still know very little now, so I can't tell you whether it's split or tapped.
The coil tap/split is operated by the tone knob - Split on 0 and Humbucker on 10. I assume the tone was defaulted to "10" as the work was being done, it sounds like it was.
The main issue is that there is more Hum when the tone knob is on 10 (Humbucking Mode) than there is on Single Coil Mode (0). The noise kicks in around the 7 mark on the tone knob. If you mute the strings with your hand it stops the Hum etc.
It's annoying enough for me to want to do something about it, although it's not catastrophically bad.
Thing is, I don't know if this is normally to be expected or whether there is an issue at all. Maybe it is a guitar that doesn't suit coil tapping?
I did a screwdriver tap test in every config. and found some interesting results, seems some Poles(on supposedly "OFF" coils) are on when they shouldn't be and sometimes, in various confis, the poles make a loud tap when on and sometimes a loud "Humming Tap" when on.
I've got the proper detailed results written down but didn't want to overload the info. I you need me to elaborate, I can.
I tested both my guitars and the VSOP (HSS) is grade A, near zero noise, that also has a Split humbucker option. The Wolfgang must have an issue, IMO.
Thanks for any help.
Only a Fool Would Say That.
As ICBM said, I'm talking about the thin black wires and the cable screens.
The ground wire to the strings is the one that goes from the back of one of the pots, through the body and into the trem spring cavity. It should be soldered to the underside of the spring claw.
It's worth having a cheap multimeter or continuity tester for problems like these. If you put one probe on the strings and the other to the jack screen connection you should see continuity (or close to zero resistance). If there is a break somewhere you will read open circuit on the meter (or at least a large resistance if it's a solder connection gone bad).
With a meter you could narrow down the exact bit of ground wiring that was at fault.
As ICBM pointed out, it could also be an issue with the grounding at the switch or the pot.
As far as the Tap / Split thing goes, it's probably a 'coil-split', A humbucker has two coils connected in series with one end ('hot') connected to either a pot or switch - and ultimately to the input jack tip - and the other end connected to the ground - and ultimately to the input jack screen. A coil-split works by connecting the join between the two coils of the humbucker to ground. This leaves one coil connected to hot and ground (and therefore 'active') and one coil connected to ground at both ends (and therefore 'off').
You could of course make a 'tapped' humbucker ... where each coil had a full and reduced power output ... but it would require six core hookup wire and the motor coordination of a brain surgeon to manage all those internal connections. Then I would imagine the sound wouldn't be that great for all the effort ... unless you had a mahoosive output bucker to begin with
