Fret wear
Just had some 85/15s installed in my PRS. Wont be able to pick up until the weekend.
Tech mentioned I might want to book it in for a fret dress as it's showing some wear.
That's the violet (newer) one. I definitely notice frets 1-5 on the orange one have some indentations.
Bloody nickel fret wire! Still, I reckon they're ok to keep going for a while yet...
How long do you wait until you get a fret dress? Or get so p!ssed off you get SS frets installed?
  • guitars4youguitars4you Frets: 14182
    Not a specific answer unless you want someone to say the sooner the better - Maybe a repair guy will say get it done now as it is good for business - maybe it is so bad it needs to be done asap
    If I trade in a guitar with obvious grooves in the frets I will have it dressed before offering it for sale
    If there are just very minor flat spots then unless you are some perfectionist then you can let it go much longer
    Without seeing it in the flesh and with out knowing if it is causing any fretting issues elsewhere then hard to pass comment - I know many will do nothing until the wear is so bad that it causes playing issues and buzzes, but to me that is to late
    A light fret dress is a dam sight cheaper than SS frets
    No specific answer but hope it helps
  • That's cool, wasn't really looking for any grand answer. :)
    Just can't believe there is wear already - only had them for just over a year!
  • SassafrasSassafras Frets: 30289
    If it's your main guitar then fret wear isn't unusual after a year but that doesn't mean it will cause problems. Fret wear always looks worse than it really is.
  • richardhomerrichardhomer Frets: 24798
    My 22 year old Martin is strung with medium gauge bronze strings and shows only very light wear. It certainly requires no attention at present.
    PRS's recommended action height is significantly higher than they can usually be adjusted to - and therefore should cope with some wear.
    My guess is he's looking for work....
  • To be fair it was only a recommendation but I think I'll hold off for some time.
  • ewalewal Frets: 2582
    I've never had any guitar's frets dressed in over 30 years playing - wear just adds to the character of the guitar. Although to be fair I'm talking about different guitars over that time.
    The Scrambler-EE Walk soundcloud experience
  • I get a fret dress when the setup ends up being compromised by the fret wear.
  • guitarfishbayguitarfishbay Frets: 7959
    edited January 2016
    I don't understand this thought process.  If there is enough fret wear to mean you need an uncomfortably high action that isn't character in the same way as a paint chip on the body.
    apart from playing the guitar a lot one of the biggest causes of fret wear is playing with dirty strings - Not saying yours is like that but take it into account
    Some players again naturally 'squeeze' the note harder - maybe not much you can do about it, but again it will wear frets down quicker
    I've seen guitars that are 5-10 years old that have no hint of wear - Other pro based players can need a dress after 12 months with constant 5-8 hours a day playing
    Take a ultra close up pic if you want and e-mail to me and I can look at it if that helps you
  • ICBMICBM Frets: 72250
    PRSs have quite soft frets, and they do wear a bit faster than some other brands.
    That said, fret wear always looks worse than it actually is, and it may only take a very light fret dress to remove it entirely. I second what guitars4you said about dirty strings - and dirty frets wear faster too, since they corrode, the corrosion scrapes off easily, then the next layer down corrodes etc. Keep everything clean and they will last longer.
    I'm not keen on stainless steel frets, they sound overly 'zingy' to me, similar to how a brand new set of strings does before they settle in, only permanently. You may like that though.
    Two schools of thought: you can't hear a problem so leave it, or - get it done now because it will get worse, faster, if you don't.
    Has anyone tried those Evo Gold frets?
    Do they last longer than ordinary nickel and are they easier to put in than stainless? By easier, I mean not so rough on fretting tools.
  • WezVWezV Frets: 16657
    I have not used them myself but most of the reports I have seen say they sit pretty much between stadnard nickel and SS
  • SS frets are a bit zingy but through an amp I think that goes away..?
    I don't believe so - they definitely sound more 'precise' to my ears - not sure whether it's greater brightness or a sharper attack.
    Paul Smith uses wire that he thinks 'sounds' good, as well as wearing in an acceptable way.
    IF - and it is a 'if' your frets need dressing, that is not a reason to go for a refret. PRS frets have reasonable height, so will stand dressing with little or no change to the feel of the guitar.
    Unless you are getting unacceptable levels of buzz, I doubt your guitar needs any attention at this stage.
    edited January 2016
    I've never had that problem - the guitar I had for the longest (about 20 years), an Ibanez Artist) had worn frets, however I never once felt it needed the action adjusted or indeed any other sort of set-up work - it just looked after itself. It also had what appeared to be a hairline crack in the neck which didn't affect it in any way. It was indestructible that guitar and I was too busy playing it to notice!
    ETA: I actually hate the fact I'm now an old bore that spends more time fettling guitars and reading pedal reviews than actually playing the damn thing and being creative!!
    there is usually a  clear point when natural wear becomes a fault that needs fixing.
    slightly worn frets are not usually an issue, most guitars that get played regularly have them.
    But if you have divots so deep it hinders bends, you have constant fret buzz on the most worn positions at an action you consider reasonable, or you are struggling with intonation on  numerous fret positions  then  its hard to characterise it as anything other than a fault that needs fixing
    how about some pics:
    these are a bit worn, but most players probably wouldn't notice too much.   they would benefit from a dress and crown, but will get by as they are.  tbh it looks like they could benefit from a dress of the ends anyway so i would recommend a dress at some point soon.
    this is similar, possibly a bit better, hard to tell from internet pics, but it looks like just a little wear and discolouration in the non-worn areas making it look worse.  a good polish might make it seem 10 time better
    this would definitely be in for a dress, but there is plenty of height to do it - nice easy job
    this is overly worn and getting quite low so a definite candidate for a refret, certainly no more than one more dress if the owner wanted to keep the original frets for some reason - and they would be very low and hard to crown properly at that.
    sometimes you see actual dents in frets, usually from  something hitting the strings against the fret.  they should always be taken care of as they can catch the string more than natural wear
    That guitar I was talking about had a chip out of one of the frets - it forced me to avoid the 3rd fret on the B string which turned out to be useful creatively - either re-tune the guitar or look for a different chord voicing. Anyway I'll shut up - I'm side-tracking the thread.
  • Good pics. Will maybe get some up at some point but super busy for the moment.. Fyi I don't think it will need any work
