Got some pedals for sale...
Lehle Little - first version, good little pedal looper. Better layout than the Boss LS-2 that's for sure! SOLD.
Boss GEQ7 - Boss EQ pedal for guitar, works well, low noise. No faffing about. SOLD.
Fulltone OCD - One of the best pedal distortions you can get. SOLD.Bright Onion Looper - this will allow you put pedals either into your amps FX loop, or into the front of the amp. £20.
Palmer Reamp box - will allow you to route guitar DI signals from your computer into the front of your amp. £45.
TC Nova Mod - Okay, this one needs some explaining. Basically I modified this when I was not all that great with a soldering iron. Consequently, it's got some heat damage to one or two of the buttons. So it looks little crappy. Pretty sure internally there is a jack socket hole too. The first footswitch enables the effect. The second scrolls up the presets. It used to be tap tempo. You probably wont be able to restore the tap tempo features due to the PCB getting too hot, and losing some of the track. So if you're happy to not have tap tempo, this could still be for you. Given all of this, it does still work, and it sounds pretty damn good. Low price of £60, given the condition.
*ALL PRICES INCLUDE POSTAGE*
Good luck with the rest mate.
Need some cash!
