Where this becomes an issue is during winter months, in centrally heated houses. Radiators quickly dry the air to (sometimes significantly) below this level,
I keep my acoustics in their cases, in a room where the radiator is turned down significantly lower than the rest of the house. I have a hygrometer measuring the room humidity. In winter, it's about 40% - which is lower than most makers recommend - but only marginally so.
I tend to dry towels in the room to help keep the level up.
@ToneControl. Would you mind sharing your setup re humidifying the room? I currently keep in cases and humidify there, but would love to have a proper setup to keep the room stable. Don't mind spending a bit as have some decent acoustics to protect. The last humidifier I bought was thrown out after a week though, as got water all over the floor, although it did only cost £40....
My house is not the driest, no. I need to move.
However, it's only been below 6 degrees outside on a couple of days this winter, and seems like it's been raining every day since the beginning of November. So for now at least, my Taylor lives in its case with only a silica gel pack for company.
Put them in your room and/or in your guitar case for a while to see if you have a problem.
This time of year is the most worrying in the UK as we have all our double glazed windows closed and the central heating on which can reduce humidititty to 20-25% and this can cause cracks etc.
Best to keep guitars somewhere between 40-60% with 50% being ideal.
If you need to humidify your guitar - ther are lots of cheap, options - keep them in their cases with a perforated soapdish with damp sponge, or even just half an apple. (changed regularly).
I use small plastic perforated tubes with high density foam inside. Don't see much point in buying the commercial stuff for a bit of damp in the UK.
However, don't let anything get so wet that drips might fall on/in the guitar itself.
Frankly, I've never found summer to give me a problem humidity wise.
We have nothing like the problems the Yanks have with their high plains areas (Montana etc) rarely getting more than 20% or Texas /Louisiana etc., averaging at 90% for much of the year.
When I got the guitar home from the shop, it dried out pretty quick and fret ends poked out, bridge sunk. A few days with the humidifier and all was well with the world.
Low humidity can be horrendous for acoustic guitars, a centrally heated house on a cold day in winter can get well below 30% as mentioned in this thread. I would not leave my guitars sitting out for extended periods in those conditions.
It's nothing to do with the 'UK Climate' really, unless you leave your guitars in the garden. It's the climate where you guitars are being kept. Radiators cranked all day are not the 'UK climate'.
@ToneControl, thanks for the info!
Erm, but you said this.
Which is all completely wrong.
Or is it only a real concern if the guitar is constantly out?
