Bust A Nut
As it says in the title.
Sadly, I can't complete the pun as it bust on the A string groove not the G...
Since I've never cut a nut before and this is my fave guitar (not one I wish to learn on), can you recommend anyone in the Bristol area to fit a new nut, probably a light dress at the same time?
A hint at cost would be nice too.
  • xwolf5150xwolf5150 Frets: 180
    edited December 2013
    If its nut work I'd recommend Eltham Jones. Don't let him touch the electrics though.
    Fitted a beautiful stainless steel nut to my strat but made a total pigs ear of the wiring on another of my guitars.
    The contrast between the two jobs was mind boggling.
    He's in Bristol
  • Are Mansons near you? (Exeter)
  • and as a quick fix axerus do pre cut nuts, that might help you get by
  • Thanks chaps.
    Exeter's a bit of a trek from Bristol, so I'll try the local first.
  • dean2371dean2371 Frets: 139
    Another recommendation for Eltham from me
  • 57Deluxe57Deluxe Frets: 7333
    many luthiers just fix them with Superglue mixed with a little baking soda...
    But for all you guys that were thinking he squished his bollock -  if you are at the stage in life where you are developing LBS - Long Ball Syndrome - DO NOT wear shorts without well supporting jockey's!
    <Vintage BOSS Upgrades>
  • bertiebertie Frets: 13568
    Thanks chaps.
    give Simon a call at Brook guitars down near Okehampton.      He does repair work as well as the obvious............. he's a mate - tell him I sent you..........   you'll get a superb job
    Failing that surely Mansons have an on-site tech ?
    This method works, I've done it on two guitars and it never had another problem.
