Hi guys and gals,
Here's a little tip for those of you that sometimes struggle to know a key just by looking at a chord progression. I won't go into too much detail over why this works unless anybody is really interested or asks nicely but here's a quick way to work out which scale to use.
Firstly, take your progression. In this case, let's use
F, Am, G, C
Then look for any two chords of the same gender (either both major or both minor) in your progression which are alphabetically next to each other.
This time, the chords we're after are F and G.
These are chords 4 and 5 in your key, so by working backwards, you can find chord number 1.
5-G
4-F
3-E
2-D
1-C
If you spot two major chords next to each other (like F and G) then they are chords 4 and 5. If you spot two minor chords next to each other (like Am and Bm) then they are chords 2 and 3.
Just bear in mind that whilst the chords need to be next to each other alphabetically, they can appear anywhere in the chord progression and not necessarily in the right order.
Hopefully this might help someone out there. If there's any questions or you'd like more detail on this, comment away and I'll go into more detail
All the best!
Also, the chord progression I outlined would be a 4, 6, 5, 1 in C. Not quite the four chord wonder in the axis of awesome vid which is a 1, 5, 6, 4 in E ( E, B, C#m, A)
Yes sorry I didn't mean to imply the order was the same, nor that your example and theirs was in the same key; just that the axis songs also had I, IV, V, vi, all following your little tip of the IV and V neighbours pointing to the I being the key. Thought it would make you smile I've changed my post
One thing to add to your tip - of course those 2 neighbouring major chords in your example could point to the relative minor of the key mentioned in the original post, in other words be the VI and VII not the IV and V. So for example in your Fm A G C example, C major might be the key, but so might A minor - for example The Passenger (Am F C G), which is i VI III VII, not vi IV I V. The "i" is the A, and the song is in A minor. I'm sure the OP knows this and obviously the key signatures are the same, but thought it worth writing, just for the sake of completeness
Regarding SHA, I think the D crowd would say it's in D mixolydian, so the key signature would be 1 sharp like G major, but the tonal home would be D, if that's where they felt it was, therefore no inconsistency between your view and theirs, from a key sig perspective at least.
Just as a point to note, and again as I'm sure the OP knows, for songs that are diatonic but are not written in Ionian, like Satriani's Flying in a Blue Dream, where the two neighbouring major chords (C and D) don't point to the song being "in G" but "in C Lydian" - in keeping with your tip, the sig would normally be written with an F sharp, ie as G major, notwithstanding the tonal centre being C (though some might favour writing it as though it were in C major and raising every F to F# - both are possible.)
Non-diatonic songs like The Damned's "I think I'm wonderful" which has a I and a II, may not have a IV and a V, so you'd have to be careful of using your tip for this or other songs with such non-diatonic progressions and borrowed chords.
The modal stuff is all bang on like Viz says. Whilst this trick will point you at the right notes, it might not necessarily give you the correct tonal centre. Someone mentioned "another brick in the wall" on another thread and that's a good example of this. While most guitarists play this in D minor, it's actually in C major/A minor but focusses its note choices around D. Which is called playing in D Dorian. I'm sticking to my guns on SHA being in G though as 2 out of the 4 bars in that chord progression (and therefore half the whole song) is G. Seems like a good tonal centre to me, just seems like people can't shake that "first chord is the key signature" mentality.
So yes, while this trick works, there is a bit more to the theory side of it. But if you only want to know which notes to play and aren't too bothered about what to call it or why it's called that then this should do the ticket :-)
Here they are, if anyone's interested in what a true 1 b7 4 4 sounds like:
Back in Black (in E)
Don't Stop Thinking about Tomorrow (in E)
Anytime (in E)
Centerfold (in G)
Lots of fun can be had discussing whether SHA is a 1 b7 4 4, or a 5 4 1 1. But that's for another thread, preferably one that's been closed.
Ed Conway & The Unlawful Men - Alt Prog Folk: The FaceBook and The SoundCloud
'Rope Or A Ladder', 'Don't Sing Love Songs', and 'Poke The Frog' albums available now - see FaceBook page for details
C E G = C Major Triad Chord
C E G Bb = C7 chord
The Bb note in C7 gives the chord the 7th sound, otherwise it sounds the same as a C Major triad. Personally I find C7 sounds a bit boring, because it anchors you to a key with no ambiguity.
