Ok through mind over matter, the sacrifice of three local stray cats and a book of mystical monk incantations read backwards, I have gained knowledge of all the notes all over the fretboard in all the modes. As a guitarist who has always been totally inept at all things theory, I have no clue at all how to use this information. I have a couple of questions:
1) How does one know when to use a given mode? I imagine that it requires an ear for music that I do not possess! At the moment I just look for a backing track called something like “G Lydian backing track”
2) Do you modal players switch modes according to the prevalent chord at the time, or do you more or less stick to just the one?
3) By and large, my modal type improv sounds like I’m just playing the blues scale in the wrong key! slight exaggeration – but it’s more ‘bluesy’ than others get out of the scale. Maybe I’m just going too much for the obvious bending. I’d like to get more of a satch/vai vibe out of say Lydian. Any pointers?
The biggest consideration is how often are you changing chords:
If it's something with a drone of one chord all the way through or two chords then you can use the relative approach to modes - it's a C major chord so try C ionian, C lydian, C mixolydian ... C lydian dominant... rinse repeat.
If it's a jazz tune with changes every other beat then you're not going to be able to do that kind of math (and it is math) fast enough. In this approach you can say I'm playing in the key of C major therefore the notes of Dm7 (the ii chord) are exactly the same as the notes for the (I chord) only the emphasis is different.
In some jazz tunes you'll probably find ii V I progressions so Dm7->G7->Cmaj6 for example. The chord tones dictate to an extent where the pull is for the scale.. you could try to play "D minor pentatonic with a major si... fucks sake then a G super locrian for ...fuck fuck change quicker!! C ionian..." - you could do the Joe Pass thing... start playing the G super locrian over the Dm7 as it foretells what's coming and that's great story telling... also it strengthens the resolution.
Essentially mixolydian is a laconic sound, ionian is happy sounding (although sad songs can be written in it) and lydian is just fucking awful - it's been raped to death and then some by douches with 80s hair-do... dorian is a little darker than the mixolydian and Carlos Santander owns the aeolian mode - you can't use it without sounding clichéd, I think some thrash band bought up the phrygian and locrian modes.
Ultimately modes are sounds not patterns, learn the sounds and you can invoke them on any instrument and understand their meaning to you...
If you're playing over a chord - that chord should serve as the basis for the scale you're chosing to play over it (or chord fragment if you dig harmonic extensions instead) G7 -> G B D F so fill the gaps as you deem suitable. There's also the concept of offsets so B D F A might sound like a melodic set of notes... or E G B D or well you get the picture - the point is scales have lots of notes and it seems odd that people want to use all of them
If I just have basic major triads in my chord progression I choose a major mode with the tonality that fits the song and then follow the chords,G major scale over a G, D major scale over the D. Now if your chords have 7ths rather than Major 7ths the scale choices become more limited (So I end up following major chords with the mixalodian).
Likewise with minor chord progressions. Any chord extensions will point you to certain scales. I.e a b9 on a minor chord will point you towards a phrygian scale.
Now when you get major and minor chords in your progression it becomes a little more complicated so you may want to prep a little before hand. So if you have E followed by F#m you could play an E Major scale followed by F# Dorian (same notes but different emphasis).
Jazz guys don't usually think modes. They think chords and hone in on chord tones with loads of passing notes.
My old guitar teacher used to play over a blues progression and use all 12 notes, but the emphasis was on the chord tones. It never sounded wrong.
a. Play by Ear
b. Play the Arpeggio (perhaps swapping the ii & V7 Arps for shits'n'giggles)
c. Play from the root scale (ie. the I in a ii V7 I)
d. Play a known lick
Modes are far more useful for describing for what you're about to play or just played
Feedback
Some great knowledge here but ........ I'm baffled!?! As soon as any theory goes 'technical' it's like people are speaking in tongues, 3 miles over my head. I just can't seem to relate at all, it's almost like musical dyslexia.
Having said that, I'm not giving up! I'll be reading through all posts a few more times.
songs tend to be written in one of these scales. Greensleeves is written in dorian. Flying in a blue dream is written in lydian. Gates of Babylon is written in Phrygian. Most rock is written in mixolydian or aeolian, or its "amodal" - it doesn't have the defining 2 modal notes out of the 7, it just uses the other 5 in the scale - it's pentatonic.
so you are right - you find a tune or vamp or backing track in a certain scale and noodle to it.
1) Modes are combination of notes and intervals. We modal players (not sure what this means it's just a tool!) pick the mode that has the right combination of the notes for a given harmony (chord being played by other instruments or at least implied by other instruments). If the harmony is not very well defined, like say just a drone of a single note, then anything goes. In that case it's important to have an idea of how each mode sounds. In general for diatonic modes, i.e. the ones derived from the major scale (Ionian mode), they go from brightest to darkest: Lydian (major with raised 4), Ionian, Mixolydian (flat 7), Dorian (like major but flat 3rd and flat 7), Aeolian (flat 3rd, flat 6th and flat 7), Phrygian (flat 2nd, flat 3rd, flat 6th, flat 7), Locrian (flat 2, 3, 5, 6, 7). Better way to learn them is to practice them loads especially over a drone. Say play a G and loop it then play g lydian, g ionian, etc. Do this regularly until you can hear the raised 4th of a lydian.
2) Depends. Some chords define what mode should be used more than others. For instance a G7 chord is GBDF. The only mode that has those notes is G Mixolydian but for example the Lydian Dominant mode (5th mode of the melodic minor scale) also has those notes. The difference is that G mixo has a normal 4th and G Lydian Dominant has a raised 4th. If you want a slightly different sound you can use Lydian Dom for example. There are literally HUNDREDS of possible modes and note combinations. The more you know the more options you have.
3) Playing modes is not a magic bullet to sounding like somebody else. To sound like Satch you need to do his legato and whammy bar and play some of his lines. Reason your Lydian playing sounds like the blues scale is because the blue note is the same as the unique note of the lydian scale, i.e. b5 = #4. Less bends more hammer ons and pull offs, transcribe some satch stuff maybe.
I think this class from Gary Burton on modes is very good and comprehensive. I think it's fairly beginner-ish but let me know if you get lost. Lots of knowledge in this forum.
Also there's the relative approach. I'll try and contrast below:
Derivative: playing over Dminor in the key of C - using the notes of C major you'll be playing D Dorian.
Relative: playing over Dminor in the key of C some of the many options you have are to play D dorian, D aeolian (a little darker), D phrygian (darker), D mixolydian (works some times)...
Try playing (V)Myxolydian over the minor & (ii)Dorian over the V7 in a ii/V7/1 - sounds great ! (or play Dorian over both or Myxolydian over both)
Though admittedly arpeggios sound a lot better (V over ii and vice versa)
Feedback
