That wasn't a price thing; a cheapo Piranha sounded exactly like a very expensive Vovox, and a homemade Klotz/Neutrik sounded exactly the same as a Pete Cornish. The latter two had a hair more treble than the former two, but only a hair.
The ones ICBM suggested are probably perfectly serviceable. Otherwise I'd suggest spending a touch more and going to Kabl.
Nil Satis Nisi Optimum
Basically your average guitar cable is a low pass filter with the resistance of the cable in series with the signal and the capacitance loading shunted to ground.
It's another plus for having EMG pick ups in a guitar. In the above scenario an Emg equipped guitar had no high signal loss at all .... none that I could hear any anyhow. It's not a scenario you're going to come across every day obviously but it is a handy little thing sometimes
The resistance of the cable is negligible to the point it's not there at all - typically an ohm or two in a circuit with source and load impedances in the tens or hundreds of kohms. It's only the capacitance that matters.
