So I bought myself a Little Smasher for some late night low volume cranked Marshall tones.
I had been quite impressed by the demo's I had seen so was eagerly awaiting it's arrival...
So a couple of days later when it arrived I greedily plugged in my Les Paul and connected it up to the celestion blue in my AC15H1TV.
I switched on and turned up the volume expecting much joy!...No joy
The thing was incredibly noisy!....Like playing in a room with lights on dimmers noisy!!
I sent off an email to Diago wondering what could be wrong and to my amazement they replied saying that the Little Smasher needs an earthed power supply and the PS they supply with it (Micropower9) is NOT earthed?!.....can anybody help me out with suggestions for a earthed PS for this thing? It would need to output at least 600mA or more at 9V.....Cheers!
Bizarre.
Get them to supply an appropriate one!
http://www.maplin.co.uk/p/regulated-9v-600ma-acdc-power-supply-l67bq
Wait just checked, the Diago needs a Centre Negative supply, this won't work.
I do follow your point entirely, but that's not what I'm saying. Under most circumstances, in Europe, the main AC is quiet enough that the Little Smasher will be quiet enough without any need for an Earthed connection, but this depends on a variety of circumstances. Adding some kind of connection to Earth simply improves the noise rejection, if that's what your situation requires.
The suggestion of using an alternate power supply is just one possible solution to improve noise rejection in your particular set-up. On a pedal board and amp system the ideal is to have one path to Earth; two or more paths to Earth can set-up a ground loop with resulting hum, but not always. Zero paths to Earth can also cause hum, but in the UK our noise is usually pretty clean (it depends what else is in the same building), and a high proportion of pedal boards already have a path to Earth. We had to make a choice - a floating power supply or and Earthed one. On balance, we chose what we deemed to be the better option.
In the US, (and a lot of other 110V countries) our testing showed that the AC mains noise was such that the only way to keep it quiet in most circumstances (even considering that some boards would then have two Earths) was to provide an Earthed power supply.
A lot of external power supply based amps (Roland Cube, etc) suffer similar problems - it's quite a difficult technical problem.
If you are dissatisfied to the point where it's not doing what you wanted or expected, and the suggestions are not ones you're happy with, your retailer should offer you a full refund.
I do completely understand what you're saying and I offer my very sincere apologies that the Little Smasher doesn't meet your needs.
Personally though I would just buy another power supply and have done with it
...Agreed, cheers guys!
This is indeed a problem with a good deal of audio equipment nowadays and it will get worse.
Manufacturers are indeed in a dilemma. Earth your own kit and run the risk of creating an earth loop or use a floating supply and risk nothing being earthed and hum being worse to bad.
This matter is not confined to "budget" gear, a good many active studio monitors now use "Class2" insulated power supplies and are earth free because one of THE most common earth loop issues arises when a PC/AI is connected to active monitors. Mind you, most makers of such gear provide a convenient earth terminal and that is an easy, cheap option. Take a wire from the metalwork, jack plug sleeve say, and connect it to earth. Radiator or the earth pin on the mains outlet.
Quite surprised the amp people did not suggest this?
Dave.
