The neck is 48mm, has a slightly cambered fingerboard and is a joy to play - the neck is really well shaped. Much less of a handful that a normal classical.
The bridge is a variation of the standard 'tie on' classical - but is easy enough once you get used to it.
Not a cheap option but very, very good.
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
very slightly radius to the f/board and narrower, slimmer, more rounded neck, not as wide s/spacing - basically all slightly modified to my own taste being a steel string player flat top player.
Fish glue and french polish throughout.
Heres a friend playing it.
http://i264.photobucket.com/albums/ii166/uilleann49/guitarfull.jpg
