PRS Custom 24 - 2013 Experience Model
thomasross20thomasross20 Frets: 4436
edited May 2016 in Guitar Reviews
PRS Custom 24 (2013) Experience Model.
Owned for close to two years now. Gigged. Hands down, this is my favourite guitar which I'd choose over all others. Ergonomic perfection.
The story is that when I turned 30, after 15 years of practising, I thought I had better join a band.
First audition (which I passed, yay) was a nightmare though as my Ibanez went microphonic, it was immediately out of tune when I took it out of its case and after that day I said that I deserved something gig-worthy. (A list of previous gear can be read on my webiste).
So I played lots of guitars over a period of months. I'm a player and not a gear-hound so it was all about the feel (firstly) and sound for me - as well as reliability and all the usual. It came down to a Suhr Pro S4 or the PRS. PRS beat it - thicker sound and I preferred the neck shape, looks etc etc. I almost walked out of the shop without having tried it so goes to show.... try everything! The minute I played it, it was like a thunderbolt hit me. The neck feels like an old friend, like it's been played in for years. Very comfortable. Although I had a vague idea of what was what, when I researched it some more back home I found it had a lot of desirable features (the pickups, the neck, etc) - so it's not like I went in aiming to buy the most expensive guitar "just because" - it just turned out that it was one of the more expensive guitars and it was the best (for me). So a sort of half-blind test, if you will. It was so good that I spent more than double what I went in with.... And I don't regret it one bit. Some people said to wait for one second hand but I'd still be waiting to this day...
Most years PRS has an Experience event (and please anybody, correct me if I'm wrong on any points here... remember, I'm no gear hound) and does a special run of guitars. In 2013 they did these flame satin maple neck custom 24s with 57/08 pups (using the old Gibson wiring machines) and special "fade" flame colour on the body. Check out the blue one - it's stunning...
Some specs:
24 frets.
Double cutaway.
Carved/countoured top.
Mahogany body with maple cap.
25" scale length (gauge 10 strings standard which feel great).
Flame Orange Fade with book-matched top.
10 top (better figuring - in some cases, it really is breathtaking).
57/08 uncovered pick-ups (classic PAF sounds).
Satin flame maple neck (pattern thin - FANTASTIC neck carve).
Ebony fretboard.
5-way blade control (no push-pull on tone pot).
Phase III (I believe!) locking tuners. Open-backed which looks cool.
Self-lubricating nut.
Nickel frets.
Mother of pearl (???) bird inlays. Quite striking.
PRS 6-point trem.
Comes with 3 springs in the back.
  • thomasross20thomasross20 Frets: 4436
    edited May 2016
    Pickup positions:
    Neck:  Neck humbucker - great for creamy lead.
    Neck-mid:  Neck humbucker split, in parallel with bridge humbucker split. Quacky single-coil sound, though "full" at the same time. I use it all the time for clean acoustic parts in particular.
    Mid:  Two humbuckers in parallel. More LPish in nature, I use this if I think distorted rhythm parts are too trebly / edgy on the bridge humbucker.
    Mid-Bridge:  Neck split in parallel with bridge humbucker. Similar to the other split position but a bit more treble and pushes through the mix a bit more.
    Bridge:  Bridge humbucker. Just amazing for solos. Has some of the snarl/grit you get from an LP when you hit the string. Just sounds alive.
    5-way blade is my preference. Easy to see what position you're in (compared to a knob selector). Also, I go from split neck to bridge humbucker a lot and this would require TWO actions with a toggle + push-pull configuration.
    57/08 pickups (and also 59/09 and 85/15) use the original Gibson PAF winding machine, apparently. Sounds fantastic. Not too powerful, not too weedy in the case of the 57/08s. Just right. I don't like high output humbuckers. Volume control cleans up distortion very well. I don't touch the tone control much but it does work well for rolling treble off gradually.
    59/09s are overwound (higher output) 57/08s. 85/15s I find have less of that syrupy magical quack of the 57/08 but they split excellently and are in between 57/08 and 59/09 in terms of output. 57/08 and 85/15 pick-ups generally can't be bought new. Note the pups don't have covers - I massively prefer this as I swear covers muffle the sound (dull the treble). The guitar sustains incredibly well.
    The guitar rarely goes out of tune. If it does, it's the G-string, maybe after lots of trem usage. But it's very rare. The most stable guitar I've come across, short of those I've had with a Floyd.
    The guitar is a nice weight yet solidly built. Well balanced (it doesn't tip in either direction). Great QC - everything oozes perfection. The fret ends and smoothed, I swear the edges of the fingerboard are slightly scalloped - it's just a joy to glide along. The satin neck is sublime, the whole package looks fantastic and I always get questions about it at gigs. The contoured body feels great. The lampshade knobs are very good looking and have "grip" so your finger isn't going to slide off them (good for control).
    I have zero worries going to gigs with this. I think maple tops can ding fairly easily, though.
    PRS 6-point (screw) trem is fantastic. The saddles are held by the trem casing so they don't jig side to side, for increased stability.
    No dead spots. Harmonically rich (though my Suhr is more harmonically vibrant, admittedly). I like the pick-up rings (sort of like the trem casing... I like enclosures!).
    With the 24 fret models, the heel is small and to be honest, non-existent. I used to play neck-through guitars only for upper fret access but I have zero problems with this. Custom 22 heel I'm not keen on.
    I repeat that the satin maple neck is a thing of wonder. I actually don't like the "gloop" neck PRS much but the satin neck versions are out of this world. I prefer maple necks to rosewood, which is warmer in tone. Maple feels /sounds snappier, lighter, airier. See GAK video in further posts for an example. The pattern thin neck carve suits me perfectly. It's round at the back with just enough wood/girth. It's quite slim. Just fits perfectly, I can't say enough good words about it.
    Headstock design is excellent. I think it looks very classy and like how the tuning pegs are on bot sides. Because of the angle, you don't need string trees like on Fenders and there's less chance of headstock breakages like with Gibsons. Yet more plus points for PRS as a builder. The headstock is flame maple and the PRS signature is embossed, so it stands out - classy. The truss rod cover looks like graphite - I'm not sure. Again - classy. I adjusted the truss rod once when I got it to set it up and haven't needed to touch it since.
    Other PRS instruments are great but nothing can touch the core line, honestly. The new CE models with satin maple necks and 85/15s come close, but no cigar.
    Ebony fretboard "feels" slick and fast. My only worry is that whenever it needs a re-fret, it's a tough wood to work with (prone to splintering if not handled properly?).
    The lower body horn looks very classy as the main body colour makes way to the brown, as can be seen.
    The case it comes with is very nice. Faux leather on the sides. Main body is some sort of black plastic which feels sturdy and looks a lot more rainproof than the more "cloth/fabric" type cases. Nice furry inside. Nice large pouch inside for storing trem bar, strings etc. Can be locked but I never do this. Case candy includes stickers, spare screw for locking tuner, allen key, promotional material, hang tag (card describing the guitar which people like to have to prove authenticity if they want to sell). The case is HEAVY and large, though. Has an almost vanilla smell, like the Gibson cases.
    edited May 2016
    Sound is between a Fender and a Gibson. So if you want one of those extremes, go for the Fender or LP.
    PRS has its OWN sound and lots of artists use them now, and always have. One of the things people praise them for is their ruggedness, total gig machines. I've AB'd my PRS vs Fender strats and Gibson LPs... it will never sound as jangly as a Fender or have the body, grunt and growl of an LP. But in my opinion, it's the best of both worlds while being ultra-reliable and super ergonomic.
    I've listed more pros than cons there, so as some sort of balance, here are some "cons":
    - Not as versatile as Suhr Modern which has 5-way blade plus push-pull plus blower switch. Saying that.. I'm all for simplicity and a 5- way blade is enough for me.
    - Expensive. Saying that... when you compare what you get versus some other builders, this really is a fake argument nowadays.
    - Poor re-sale value at the moment (though great second hand deals to be had) on PRS.
    - Some people feel PRS can sound sterile.
    - Nickel frets wear out faster than stainless steel, but are less "zingy."
    - Some people wont like the scale length (25") on 24 fret PRS. Also, the pups are closer so the neck isn't as distinguishable as in a 22 fret model.
    - The carve top can be a bit sharp if you lean on it a lot.
    - Some people say the string grooves in the self-lubricating nut widen quicker than with other nuts - I hope not.
    - Strap buttons appear to be larger than normal. So you'll need to widen your strap holes.
    - Volume drop when splitting coils might be annoying for some. I'm actually used to it now!
    I've tried many, many (high-end!) guitars since getting mine but every time I taken this out of its case, my breath is taken away with all aspects of this guitar. It's annoying in some ways as I want the next best guitar but this is it! To get a core line guitar with these sort of specs now... the price has gone up. 57/08s only seem to come in private stock / artist models which cost even more. Satin necks seem to be reserved for special runs or wood library models. I'm glad I got mine when I did.
    Any questions, fire away.
    I'll post a whole bunch of pics / vids now.
    Live, neck position through a Blackstar, Riot Reloaded distortion.
    Live, bridge position through a Blackstar, Riot Reloaded distortion.
    Three videos detailing the differences between pickup positions using clean and crunch settings.
    Also includes (covered) 59/09 and 85/15 comparisons. I wont re-post these in other threads but shall link to this post instead.
    edited May 2016
    Lots of pictures....
    Cleaning and string change tonight for a gig on Saturday:
    edited May 2016
    GAK rosewood vs maple necks:
    Forgot to mention....Great support from PRS - they send out replacement/missing parts free of charge usually... and when I had a problem with one of my pickups (rare, apparently)... they sent out the switches and a spare 57/08 pup so I could get the work carried out under warranty.
    Here is the bridge position live (think wah was kicked in, though):
  • richardhomerrichardhomer Frets: 24797
    edited May 2016
    Awful review Thomas. I'd have expected you to put some effort in man!
    Too much?
    I think I got the pup selections wrong - will have to update :)
  • ennspekennspek Frets: 1626
    Excellent review. Thank you.
  • TTonyTTony Frets: 27432
    OK, so this gets the prize for review-of-the-year-to-date.
    Nice work
    And great to see/watch some vids too.  Thanks tommy6.
    edited May 2016
    Cheers, guys.
    I still have to amend the pup selector bit and will get onto that. [edit - done!]
    Hopefully get time to do review for the Suhr and maybe Blackstar etc.
    Cheers!
  • LozboyLozboy Frets: 80
    Many thanks for taking the time/effort on this review.I really enjoyed the trip.
  • Thank you! :)
  • sweepysweepy Frets: 4180
    PRS are bloody stingy with the nylon bush for the trem arm, if you want a new one you have to buy it complete with 6 new saddles and screws, terribly wasteful and expensive if all you want is a new nylon bush
  • BigLicks67BigLicks67 Frets: 766
    Nice work
    It would get my vote.
  • monofinmonofin Frets: 1118
    I read this twice looking for the price.... Doh!
