Gaffer Tape
RocknRollDaveRocknRollDave Frets: 6480
edited May 2016 in Live
Serious question: Where do you buy your gaffer tape from?
It can retail for over a fiver a roll if you go to the wrong place, where can I get cheap rolls that are decent quality?
  • ESBlondeESBlonde Frets: 3582
    Thomann. Tack it on a bigger order.
  • maltingsaudiomaltingsaudio Frets: 3116
    edited May 2016
    Buying it a roll at a time is always going to be expensive,
    www.maltingsaudio.co.uk
  • StageStruckStageStruck Frets: 102
    Poundland? They sell cheapie DIY stuff, so I'm guessing they sell Gaffa tape.
  • RolandRoland Frets: 8693
    They sell tape, but not necessarily something with Gaffer tape strength
  • sgosdensgosden Frets: 1993
    There's a shelf full at work... well slightly less full ..
    LOVE THE GAFFER TAPE
    the ONLY things that's been constant on my pedal board since I started gigging 10 years ago
  • David5150David5150 Frets: 118
    Toolstation / screwfix does decent fabric tape - strong as anything
  • vasselmeyervasselmeyer Frets: 3671
    edited May 2016
    Once I drove back from a gig in an old Transit where we had to use gaffer to fix the front wing back on. Legendary stuff.
  • Danny1969Danny1969 Frets: 10398
    CPC.co.uk sell it quite cheap, that's where I get it from.
    If you can't fix it with Gaffer tape you haven't used enough unless it warrants a permanent fix which is obviously cable ties :)
  • mike_lmike_l Frets: 5700
    If it's anything like their superglue it'll be shite.
    Beware of the difference in gaffer tape, duck tape and just cloth tape. They each have thier uses.
    Both are quite strong and usually black, but proper gaffer tape can be removed and does not leave a sticky residue. You can reliably stick a contact mic inside the lid of an expensive grand piano with gaffer tape, do it with 'cloth or duck tape' and you will be handed a big bill for the clean up or restoration!
  • EricTheWearyEricTheWeary Frets: 16293
    I tend to use duck/ duct tape which is widely available and comes in different colours. Not had significant problems with residue but then it is mostly for quick fixes or for pub carpets. I have bought stuff called gaffer tape and found it quite hard to use, twisting up terribly. I think I bought my last roll of duct tape from Wilkos which is a huge roll and I'm fairly sure cheaper than B and Q ( well, everywhere is cheaper than B and Q on everything).
