Acoustic guitar pickup woes and advice ...
4114Effects4114Effects Frets: 3131
edited May 2016 in Acoustics tFB Trader
My lovely new guitar comes with the LR Baggs Anthem pickup system, which I've been struggling to get to grips with. The guitar itself is lovely, very full and resonant, with a decent amount of bass thanks to the Cedar Top. Strummed acoustically it's just lovely, really punchy and alive.
I use the guitar mainly in a Church setting - we're a relatively small band - keys, drums, acoustic guitar, bass and a couple of backing singers, so when I'm playing I'm usually driving the songs along with some pretty heavy strumming.
The guitar came fitted with the Anthem system, which is supposed to be one of the best that Baggs make. However ... I'm struggling to make this work live.  For starters I have to employ a huge amount of low cut on my Fishman Platinum Pro preamp. If I DI direct to the PA with the on-board dial set to "mic" the amount of low end is stupid and it just sounds wooly and terrible. If I turn the mix all the way back to undersaddle it has that harsh piezo sound which sometimes works well, but if I strum too hard it distorts badly! Once I've done some drastic EQ adjustments on my preamp pedal I can get some nice acoustic tones, but it takes a lot of work.
I've realised that a "nice" sounding acoustic guitar isn't necessarily what works well in a full band setting - maybe I've got used to the sound and feel of the piezo systems on my other acoustics, which seemed to cut through and work better in a band context. The subtlety of the mic system soon gets lost and falls to pieces a bit when I start strumming a bit harder.
So  a couple of questions -
1. Given that this is an expensive flagship pickup system, is it possible it's been fitted wrongly to my guitar? I'm half thinking of taking the guitar back for them to have a look at. I was expecting to just be able to plug in and get a nice acoustic tone without all this work. None of my other piezo equipped guitars distort when I strum them.
2. If it is working correctly, do you reckon it's just not the pickup system for me? Maybe the anthem is more suited to laid back intimate James Taylor sort of fngerstyle stuff, not aggressive strumming in a full band?
3. Think I might be better with something like the M1a active soundhole? I know it won't sound like a pure acoustic but it might work better for the things I'm doing.
4. Anyone else have an anthem that has had similar issues?
Any advice greatly appreciated as I'm getting frustrated here. I was getting a better live sound with my £400 piezo equipped guitar than with my lovely new £1600 hand made instrument and it's driving me crazy.
«134567
  • ICBMICBM Frets: 72307
    I'm not actually familiar with either the Anthem in detail (I've heard one in a guitar, but never worked on one) or the Fishman Platinium Pro, but I would start by saying that all electro-acoustics are the work of Satan there may be some sort of mismatch between them.
    I generally find systems like this work best when kept to a single manufacturer - that way there is a much better chance that they've been tested together and there are no unexpected problems with levels or frequency balance. Going direct to the PA without a preamp doesn't necessarily mean you'll get a representative sound either.
    I also find onboard mics more of a curse than a blessing to he honest - they almost always cause more problems with feedback and low-end boominess than they fix by sounding more 'natural'.
    It is also possible that the system has been fitted wrongly, or that it's faulty - unfortunately this isn't too uncommon, and generally fixing them is a major problem unless you can simply substitute another onboard preamp, they are not usually easy to work on and many use multi-layer construction and surface-mount parts.
    I have to say that electro-acoustics are one of the major banes of my life as a repairer and that is one of the main reasons I use a passive undersaddle transducer and an outboard Fishman Aura preamp on my acoustic...
  • 4114Effects4114Effects Frets: 3131
    Thanks @ICBM
    I actually bought the platinum pro outboard preamp to try and combat the issues I was having with the pickup, which it has to a certain extent. I'm just not sure I want to go through that amount of fiddling at every different venue.
    Any experience with the LR Baggs M1a? I'm considering returning the Platinum which I only bought last week and getting one of those instead. I'm not massively fussed about how natural or lifelike the acoustic sounds, as long as it sounds good on stage and as part of the band. I'll be adding a little reverb and compression / delay anyway as I like to use a few effects for my live acoustic sound.
    Yes, it's very good. To me it sounds a bit grittier and more characterful than the Fishman Rare Earth, and possibly a little more natural but is more prone to feedback, because it has a body movement sensor. The Fishman is very hi-fi and can sound a bit sterile.
    Both of them work better in a band mix than the 'nicer' systems with a mic that are trying to sound like a natural acoustic guitar.
  • WolfetoneWolfetone Frets: 1479
    I have a B-Band on my Tanglewood and it never really sounded a good representation of the guitar itself until I removed the undersaddle and fitted a B-Band body transducer;
    This transformed the sound completely. I also play in a very echoey church with no feedback issues whatsoever. All's good!
    In your case, it looks as if you can't get a better preamp if the blurb is to be believed. Could there be a problem with the venue itself? Have you tried it anywhere else?
  • crunchmancrunchman Frets: 11446
    I have a blend pickup on a Martin I use in church.  It's Fishman rather than Baggs but it's the best sounding pickup I have used.  The K&K Pure Mini is the next best.  I had a Fishman Rare Earth in couple of guitars in days gone by and I didn't like it - the blender and the K&K, and even a plain piezo undersaddle sounded better to my ears.  Maybe the Baggs magnetic is better than the Fishman one.
    With blenders you do need the mix to be about 75% piezo and only 25% mic.  The guts of the sound still comes from the piezo, and you add a little bit of mic to make it sound a bit more real and tame the piezo quack.  If you add more mic than that it will sound woofy and will be very feedback prone as well.
  • mgawmgaw Frets: 5258
    edited May 2016
    K&K works for many with a decent outboard pre amp...headway edb1/2 can be had cheapish and are excellent...i also thought the Anthem was meant to be excellent too....i would get it checked out as i know the placement of it is pretty important.
    TBH if you are strumming away in a band i wouldnt have thought the finer points of your acoustics tone is really going to matter..soundhole pickup would be a simple solution though a compromise....
    Yeah I'm beginning to think the anthem has been installed wrong.
    From reading various forums it's intended to sound best dialled 75% mic 25% pickup or even 100% mic. The system has a built in crossover - the under saddle pickup is only supposed to handle everything below 250hz and the mic everything above.
    When I dial it towards mic it's got so much bass it's unusable without severe EQ. Which doesn't make any sense.
    If I dial it towards pickup it sounds like the familiar piezo I'm used to, but it has a horrible bzzzzt distortion if I strum it too hard.
    Bah.
    sounds like its either been badly fitted or has a problem...seems strange that both elements have an isuue..
  • LewyLewy Frets: 4192
    Post about it on the LR Baggs forum too. Their support guy (Caleb) is very responsive on there and will help you troubleshoot whether it is an installation issue or not.
  • maltingsaudiomaltingsaudio Frets: 3127
    CHANGE THE BATTERY
    www.maltingsaudio.co.uk
    edited May 2016 tFB Trader
    CHANGE THE BATTERY
    THE BATTERY IS FINE.   :D
    CHANGE THE BATTERY
    Are yu sure? As its new the same battery has been in it since it was made worth replacing it and seeing if it makes a difference
    CHANGE THE BATTERY
    It's got a battery level indicator on it. Shows full 5 green lights.
    edited May 2016
    Still wouldn't trust it, but hey your call
  • alcxamalcxam Frets: 112
    I've never used an internal mic on an acoustic that was worth the effort... who ever thought that micing the *inside* of a resonant box was going to sound natural or good??? As noted previously, just a litle of it mixed into the piezo signal will slightly lessen the 'quack', but it's not a replacement for an external mic by any means.
    The position of the internal mic will have a massive bearing on the sounds it will produce - most I've seen are on a flexible neck so you can play with the positioning to get the 'best' sound.
  • thomasross20thomasross20 Frets: 4436
    I'll read this thread later as I was strongly considering a Baggs system for my Larrivee.
    Baggs lyric is the best sounding but mic not meant to be great for feedback.
    Tried an element. Was good though not as good as the m1 which is feedback resistant. Neither as good as the lyric, sound-wise.
    It's been about a year and I STILL debate whether or not to get something fitted... or get another pre-fitted acoustic.... or just mic up if I EVER use acoustic live (never have done to date)
    Think if I went for something it'd be an m1/m80 as more feedback resistant. Even then, wouldn't be sure where to get holes drilled to widen the jack hole and to add a strap button..
    The m80 is active AND passive (option) and I think I'd prefer active straight into PA. No need for pre-amp... keep it simple
    Anybody tried m80 vs m1a? M80 meant to be less feedback resistant yet more acoustic-like (seems to be the general trend)
