FS: Bare Knuckle Blackguard Flat 50 Tele Neck Pickup
GagarynGagaryn Frets: 1553
Bare Knuckle Blackguard Flat 50 Tele Neck Pickup with a separate ground wire fitted to the cover so it is ready to use with a 4 way switch if this is your intention - will work perfectly with a 3 way switch too - you still just solder this extra wire to the back of the volume pot with the other grounds.
This is what BK say - "Scatter-wound by hand with 43AWG plain enamel wire on both bridge and neck, this is pure Broadcaster heaven. The hottest of the four sets with a thicker zinc plated steel baseplate, flat profile magnets and authentic vintage 'flat top' deep-drawn brass cover; the Flat 50s have a simply massive sound. Chunky bottom-end and snarling mids create a throaty tone with excellent natural sustain that can really push a tube amp hard."
It's Alnico V and BK claim output is 6.8KΩ but when measured by me it is 7.1KΩ - so pretty hot for a Tele neck pickup. As you'd expect from BK - top quality build and sounds great.
Wire is full length, perfect working order. These are £80 from BK so I'll take half that - £40 posted.
