FS: Catwisker Mini Humbuckers
As per title, great sounding mini humbuckers, great condition, just some surface scratches on the chrome covers as you would expect.
£55 for the pair posted to your door. Price includes cream surrounds if you so want them.
A bargain me thinks.
Note: bridge pup has about 19cm of wire left, neck has about 28 cm.
Also note from the third pic that one side of the neck pup mounting hole has something welded to it! It didn't cause an issue when I had them in my guitar as I used wood screws to mount which pass right through, but if you are using bolts I'm not 100% sure this hole would match the other 3 (I don't have the right size bolt to try).
