Hi folks,
I'm used to using my PC running windows to put demos together. I record into reaper and, since I'm not much of a drummer, select drum loops from addictive drums, which always sound way better than anything I come up with and is loads quicker than programming drums, which I don't rally enjoy.
Sadly, however, my PC seems to have finally given up the ghost, and since I got an iPad with work, I don't actually use the PC for anything else. My only computing needs at home are browsing the web and recording music. Therefore I'm wondering if I can basically migrate my existing way of working to the iPad?
Is there an equivalent of addictive drums which is as good and as easy or easier to use? Can you still work with reaper and vsts and vstis in the same way? Is there some sort of connector I can buy so I can use my existing external USB sound card?
Cheers for your help
