For sale is a Set of two custom one off pedals made by Ryan of dr scientist sounds.
First up is the cleanness eq/ boost
This is number 1 of the current version of the pedal in custom white sparkle and grey graphics.
Also included in the price is an op amp buffer Ryan built for me. It has soft touch on and off and a blue led!
I'm asking £180 for the pair including special delivery
http://i1219.photobucket.com/albums/dd436/Andy_cowman/IMG_20140103_114600.jpghttp://i1219.photobucket.com/albums/dd436/Andy_cowman/IMG_20140103_114615.jpgHere's the cleanness spec
It buffs, it boosts, it equalizes! Like the Swiss Army Knife of guitar pedals, the Cleanness accomplishes a range of tasks in a small, cleverly-designed package. Boost your amp's tone, change the gain of other pedals in your signal chain, fine tune your guitar output until it's just right. Take disparate particles of primordial ooze and compress them into the solid tone necessary for a new civilization to spring forth from.
Operation:Mono input, mono output
Power Requirements:9VDC @ 30mA, 18VDC @ 60mA
Input/Output Impedance:500kOhms/1kOhms
Bypass:True bypass using soft touch switch and relay
Bass:+/-15dB peaking filter centred at 100Hz
Midrange:+/-15dB peaking filter centred at 800Hz
Treble:+/-15dB peaking filter centred at 3kHz
Gain:Op-amp based, range from less than unity to large boost
Vol:Passive resistance to ground
Mix:Dry at 0, wet at full
Expression Control:Controls Mix knob, TRS input, 50k
Warranty:Limited Lifetime
Mate, I do wish you wouldn't keep selling such fantastic gear. That is truly gorgeous...
BUMP!
