Most common thing to go on these though is 12v bulb and \ or power supply board which steps down the mains to the high current 12v
didn't get any leads with them - have three slaves plus the one master
the slaves just sit there whirring and looking happy but projecting no light.
That setup looks like only the master interprets DMX and passes on the signal to the other lights. However you said you can see it has a mic built in so it can probably be set to sound to light .... you may find the dip switch to do that is under a flap somewhere though rather than external
