No, they're not all the same. You've bought a regular five-way switch, which you've discovered is wired differently and will limit your choice of pickup combinations. You really need an identical Ibanez switch to simplify the process for you or a Fender "super switch" to get the original combinations. If you go the route of using a non-Ibanez super switch, you'll find the wiring options here.
No... they're not all the same.
The one on my Strat has a permanently wired talent-filter. Makes everything I play sound like crap.
Oh well, lesson learned and i've now got a spare for my two strats
One side of the switch does the pickup selection - so the common tag is the output (you'll have to look to see which is the common one - it's the longest one that is always in contact with the strip
The other side is where you will make the coils splits short out a coil
Ignore the long common tag on this side and connect an earthed wire to the centre of the remaining tags.
Then each of the coil split wires from the two humbuckers will go on the remaining two tags
You'll have to look to see which tag is which so that when the switch is in position 2 or 4 the relevant coil tap point is also connected to the earthed wire on the middle tag.
I presume that the only reason the strat switch didn't work was that you just tried to transfer the soldering to what you thought were the matching tags in a line without checking the actual functionality of the switch. It will work - we used to put them in Jems and RG550s all the time
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
Get a proper CRL - the standard 5-way - it can be wired like the Ibanez switch and it will probably never break. You don't need a Superswitch or anything else special.
It sounds from the description that you might actually have one, in which case it just needs wiring correctly. Bizarrely, I can't seem to find a diagram online… the best I seem to be able to find is this comparison diagram:
http://alloutput.com/wp-content/uploads/2012/08/5_way_switch.jpg
Essentially, on one side of the switch, 0 goes to the volume pot and 1, 2 and 3 to the pickups. On the other side of the switch, 2 goes to ground and 1 and 3 to the coil-split wires.
(To be fair, Oak Grigsby aren't too bad although I've had a couple of slightly faulty ones from new, but they could be fixed easily.)
I did indeed get a CRL and had a good go at wiring it up yesterday ( only took a year) and all is good apart from Pos 1 ( bridge bucker) it sounds weak, I'm guessing it's out of phase. Is there a quick swap that will remedy this?
I tried my bested to follow @icbm 's instructions above btw
For phase testing look here https://youtu.be/OcuvBRZPpow
