blues scale for 4th chord
hi all,
im studying the blues at the moment. i understand the scales and the chords but when i go to the 4th chord, the scales just don't sound "right" although theoretically i am using the right scales.  im wondering how you approach the chord.
  • octatonicoctatonic Frets: 33780
    Which blues progression?
  • John_PJohn_P Frets: 2749
    I probably try to use target notes based on the chord and texture I'm aiming for as well as the blues scale from that key.
    What scales are you using?
    12 bar blues
    pentatonic
    pentatonic blues
    started to experiment with major blues
    finest1 said:
    12 bar blues
    Yes, I know that.
    Is it a minor blues, a dominant blues, a major blues progression with a dominant V chord?
    I suggest you look at targeting chord tones too.
  • BradBrad Frets: 658
    If you're doing a dominant blues you can try the 'minor 6 pentatonic' over the IV chord. It's just the minor pentatonic but replacing the b7 with the 6th. In the key of A...
    Minor Pent - A C D E G
    Minor 6 Pent - A C D E F#
    There are a few options but this will enable you to outline the IV chord (D9 sound) whilst staying in a familiar pentatonic land. Robben Ford uses this a lot.
    Good suggestion.
    I think off this as selecting notes from the Dorian mode.
  • you're miles ahead of me. I was sat here thinking theres only three chords in a 12 bar blues.
    How very rock and roll
    edited September 2016
    There are loads of different blues progressions.
    For example:
    I IV V
    I IV V7
    I7 IV7 V7
    Also every time you see a dominant you can play a ii7 V7.
    A bop blues progression, with some substitutions could be this:
    I7IV7I7v7 I7
    IV7♯IVo7I7V/ii♭9
    ii7V7I7 V/ii♭9ii7 V7
    Good suggestion.
    It always interests me how the same information can be viewed/applied differently.
  • octatonic said:
    finest1 said:
    12 bar blues
    Yes, I know that.
    not minor blues
    chord progression for example
    A7
    D7 or D9
    E7 or E9
    Ok, so a dominant blues.
    You have a few options.
    The scale or mode that fits best is the D Mixolydian but running the up and down a scale will get boring quite quickly.
    Look at playing phrases that incorporate the major 3rd and flat 7 of the D chord on the down beats of the IV bars arriving at an exit point that has a root, 3rd or flat 7 of the next chord.
    So a IV -> V movement target F# and C arriving at a E, G# or D.
    So for a IV -> I, target F# and C arriving at an A, C# or G.
    Phrasing is everything here.
    You can also play the A harmonic minor over the IV chord.
    A harmonic minor: A B C D E F, G#, A.
    It gives you a clash against the D7's 3rd but it will work, the same way you get a 'nice' clash playing the minor pentatonic  over a major chord. It helps if you play the f a little bit sharp.
    Or the A melodic minor: A B C D E F# G# A: Here you have no clash against the D7's 3rd: F#.
    Both these make a nice transition to the V chord where you can play an F melodic minor over the E7.
    Or just a D major pentatonic. If you only know minor then play B minor pent over D7.
  • stratman3142stratman3142 Frets: 2192
    You can a,so play the A melodic minor over the IV chord.
    A melodic minor: A B C D E F, G#, A.
    I think you mean A harmonic minor for A B C D E F G# A. Sorry I'm being an anorak again. But I take your point.
    I might play a G# against D but, at that point, I probably wouldn't be thinking scales, but more in terms of adding a b5 to a D7 arpeggio. I might think in terms of a combination of an A melodic minor (ascending) and a straight A major over the V7 (E7), as that obviously contains the G# as a major 3rd of E7.
    As has been said in an earlier post by @Brad it's very interesting how the same information can be viewed and applied differently. I'm sure that different musicians use different approaches to arrive at what is essentially the same thing. Even within my own playing, I like to look at the same thing from multiple viewpoints. Maybe that topic merits a thread in its own right.
    It's not a competition.
    I'm assuming that is just a typo by @octatonic and he meant F# instead of F as mode 4 of the A melodic minor is D Lydian Dominant, which works over the IV chord.
    Edit: Ignore, I just re-read his post. I'll leave for him to clarify.
    Gah, I was posting on iPad early in the morning- yes, Harmonic minor.
    I was got fed up with struggling with the iPad and intended to edit once I got up but got busy and forgot about the post.
    I've edited my post to reflect what I wanted to say, fixed typo's etc.
    pentatonic
    pentatonic blues
    Assuming you're playing the chord progression you posted earlier
    A7
    D7 or D9
    E7 or E9
    I would have thought an A minor pentatonic would also work over the D7. There'd be a problem sticking with A major pentatonic over D7 because you'll have a C# clashing with a C in the D7 chord, so you'd have to be careful with your note choices.
    One way to approach these things is to listen to how other players apply the scales. I've always seen the Clapton solo to Crossroads as a masterpiece in blues rock soloing and there's a good tutorial in the clip below. You can try more exotic things if you want it to sound a bit Jazzier.
  • newi123newi123 Frets: 860
    Well worth reading this Carl Verheyen article about your options here:
    http://www.guitarplayer.com/guitar-player-101/1025/the-four-levels-of-the-blues/49191
  • JalapenoJalapeno Frets: 6385
    For a beginner soloing 1 4 5 dominant 12bar, you can stick to the single blues scale throughout, with root on the 1 chord.
    They'll all fit in, but some notes will sound better than others over each chord, use your ear for that. Learn the fingering above and below, so you don't get stuck in the same blues box pattern and can slide in & out.
    In time to come though it'll be hard NOT to do this approach
    Varying the approach is what all that ^^^^ is about !
    Feedback
  • thanks for all your comments and suggestions. i will give them all a try. please feel free to add more ideas =)
    That is excellent.
