I have a super-jumbo size acoustic guitar that was factory fitted with Fishman Presys+ electronics with a Fishman Sonicore transducer. That transducer looks rather like a 3mm dia copper sheathed coax cable lying below the bridge saddle. The problem I am having is that the low A and E strings are noticeably louder than the other strings when plugged into a quality acoustic amp. This is even with the bass controls rolled back on the amp and guitar. Played acoustically the strings are reasonably well balanced.
I have checked that the transducer is properly seated in the saddle slot and runs the whole length. There's no dust or debris in the slot. I've also checked that the bottom of the saddle is perfectly flat by placing it against glass and against a quality straightedge. The saddle is not tight in the slot. The only point that might be relevant is that the transducer cable enters the saddle slot from below at the low-E end and turns 90deg at that point to lie flat in the slot.
Has anyone here overcome similar problems or have advice as to what I might try next please? Any suggestions gratefully received
Thanks
Jim
If it was me personally I would remove the whole damn lot, fit a K&K Pure Mini body transducer and an endpin jack, and get an external preamp. But that's because I have an deep-seated hatred of Satan's Work electroacoustic guitars and their pickup systems, largely for reasons such as this…
And to be fair, I still have undersaddle transducers in my own guitars, although I've removed the rest of the electrics.
I'll check the transducer for a possible break by perhaps tapping it gently along its length while amplified. But I have to say that there is reasonable signal level from the 1st - 4th strings when compared to the Fishman Matrix system in my Atkin. It's just that the fifth and sixth strings are particularly loud.
