I'm looking towards running an Atomic Amplifire straight into the P.A., in stereo, for my new 3 piece rock covers band.
A few reasons for this are that it will be a lot easier for me to transport everything (including P.A.) to and from gigs, as I will be using a Yamaha DXR 10 for monitoring guitar and my vocals.
Also, I have been wondering for a while if it is sometimes a waste of time taking valve amps to some smaller pub gigs in the first place as they are often hardley ticking over due to the volume issue and not being run to their full potential. Even the lower watt amps. Therefore, the desired tone or sustain is not being acheived.
I have run a direct system before, this was about 20 years ago and I was using a Rockman XPR stereo preamp. Compared to today's tech the Rockman can't compete, but the sound of super wide stereo guitar in a live rock band at reasonable volume had many advantages over a conventional amp set up.
As thry improve the software and effects side of it, the AF should get even better. Great piece of gear for the money.
I'd also suggest considering in ear monitors as well as that will completely remove feedback issues and give you more floor space in tight venues.
I've just left my current band and I'm not planning on gigging for a while so I'd consider selling my Amplifire if you were interested.
Are they *That* good?
I take it they feed from the PA so if i'm using a traditional amp i would have to have it mic'd?
Is that how they work or have i missed something? Is it an overall monitor of the whole band? Vocals?
Never used them so not trying to sound thick, although to fair that's not difficult for me.
EDIT:
Like when i hi-jack a thread like this without strictly realising i've done it !
My apologies - Nick PM me if you want to.
When you get a decent monitor mix you can hear everything perfectly. If the monitor mix is wrong then you are buggered. (You need a desk that can provide a monitor mix and everything mic'd or DIed)
You don't end the gig with ringing ears, but you don't get the excitement of the live atmosphere which some people really don't like.
Another plus is that you don't need wedge monitors so you have less crap to cart around and the stage volume can be lower so you don't tend to have feedback.
The latter applies equally to modellers.
The other thing I've been using is a plexi glass screen which also works quite well.
I run an 11r currently, with a Valve Preamp, and bypass the cab sims.
Cant fault it.
